I have the DEO nano SOC and it looks like the Ethernet module is connected directly to the HPS. I can read/write data through the ethernet port... (PC--Ethernet--HPS) using c code. It looks like any data entering the rj45 cable goes through the HPS. The HPS has a fifo buffer system where I can "fread" an array from a file on a PC and get elements from the array as needed. I would like to do something similar with the FPGA component where I can input consecutive integers, use verilog or "block" style code to get data to my gpio ports.
I am working on the following protocol: PC--Ethernet--HPS--bridge--FPGA--gpio. I have the first three working and I understand how to get the last two to work. Is there an example that allows one to set up the FPGA to read data stored in a fifo buffer where one can get and process it as needed? Is so, please direct me to that source. Thank you.- Tags:
- gpio
Hello Doug,
Can you please help me, i dont know where to start from PC--Ethernet--HPS. Please help me. Do you have any tutorials or codes ? Thank you.- Mark as New
--- Quote Start --- I have the DEO nano SOC and it looks like the Ethernet module is connected directly to the HPS. I can read/write data through the ethernet port... (PC--Ethernet--HPS) using c code. It looks like any data entering the rj45 cable goes through the HPS. The HPS has a fifo buffer system where I can "fread" an array from a file on a PC and get elements from the array as needed. I would like to do something similar with the FPGA component where I can input consecutive integers, use verilog or "block" style code to get data to my gpio ports. I am working on the following protocol: PC--Ethernet--HPS--bridge--FPGA--gpio. I have the first three working and I understand how to get the last two to work. Is there an example that allows one to set up the FPGA to read data stored in a fifo buffer where one can get and process it as needed? Is so, please direct me to that source. Thank you. --- Quote End --- Hi, were you able to find a solution to this problem? I am trying to implement similar thing as well but no luck till now. Thanks.
