6210 Discussions
Development kit powers off, won't power up again
JSambrook_CSSI_FPGA
I have a Stratix 10 GX development kit purchased from Mouser a few weeks ago. It's been working well and I have been pleased with the kit.
Today, I had it sitting on my bench, connected to my development laptop. I had run the board test program previously and the system seemed to be in normal operating condition.
After about 30 minutes of the board being up and running, it powered off. The board felt warm but not hot. I assumed it had just hit some kind of internal temperature limit and powered off.
I left the board to cool for 30 minutes. It was then definitely cool. When I slid the switch (SW7) to power it on, as I normally do, the blue LED (D45) illuminates, but nothing else seems to happen. No other LEDs illuminate and the fans do not start running as they normally do.
I tried unplugging the power supply and leaving the device for another hour, yet the behavior is unchanged.
The board is in factory-default switch settings and has not been reprogrammed at all. As far as I know, it's still in as-delivered condition.
Are there any debugging or reset actions I can take, or should I contact Mouser to request an RMA? This appears to be an early-life failure, as far as I can tell.
Thanks in advance for any help you can offer.
John Sambrook
Common Sense Systems, Inc.
JSambrook_CSSI_FPGA
The board has not failed in the same way since it failed the first time.
You can go ahead and close the case. I have a paper trail of this problem to
fall back on if it happens again.
Thanks for checking in.
John Sambrook
sstrell
I had 6 of these boards have almost a similar problem!  They would shut down in this manner after a random period of time.  However, in my case, flipping the switch off and on brought them back, but then after more random time, they would shut off again.  They were in open air just like you have it so it did not seem like a thermal issue.  I have a number of additional boards that don't have this problem at all.
I just RMA'ed the bad ones.  It was impossible to reproduce reliably to diagnose since I had no idea how long it would be before a board would shut down.
JSambrook_CSSI_FPGA
Thank you for taking the time to comment. Genuinely appreciated.
Believe it or not, my board came back to life yesterday. I have no idea why. I had completely disconnected it and was looking into sending it back to Mouser for service. On a whim, I thought I'd try one more time (it had been a couple of hours) and, oddly, it powered up.
I will work more with the board today and see how it goes. Now I notice that I'm concerned about leaving the board running for very long, as it's the only one I have and I'm trying to complete a project with it before the end of the month.
It would be good to know, from Intel, what the data is on boards failing in the field and having to be returned for repair. When I talk with Mouser, I'll see if I can get any data from their customer support.
John Sambrook
Fakhrul
Hi JSambrook_CSSI_FPGA,
Could you help check and try program with your own Quartus design? This is to verify whether the dev kit board is still functional or not. Provide screenshot of your tasting.
Fakhrul
JSambrook_CSSI_FPGA
Hi Fakhrul -
I was able to program the board this morning with the PCIe design from the
Board Test Kit examples for the board. I have not tested it in a PC system yet.
I heard from Mouser the procedure for returning the board via RMA. I am going
to work with it for another couple of weeks. If I have more problems like the one
I reported above, I'll contact Intel to have an engineer evaluate the case to see if
an RMA is appropriate. That is part of the procedure communicated to me by
Mouser.
Thanks for your help.
John Sambrook
Fakhrul
Thank you for your response. I wish to follow up with you about this case. Do you have any further questions on this matter?
Else I would like to have your permission to close this forum ticket at this moment. Hence, this thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
Fakhrul
JSambrook_CSSI_FPGA
John Sambrook
