6159 Discussions
HELP!!! Qsys PCIE miss interrupt
I run the "PCI_Express_in_Qsys_Example_Designs" sample on "Cyclone IV GX starter kit" board.
Running SGDMA successed.
I want to know wheather DMA is ended by using interrupt. But i can't get the interrupt notification all the times.
Environment is:
WindowsXP SP3
Jungo WinDriver
PCIE send "legacy level-sensitive interrupt"
Steps:
1. enable interrupt at 0x0050 register
2. clear interrupt state 0x0040
3. useing WDC_IntEnable register IntHandler function
4. listen in IntHandler function
5. clear 0x0040 interrupt state in intHandler function
6. printf("Got a interrupt\n") in IntHandler function
I can't get the interrupt all the times.
I also got the same result by using "MAILBOX" testing.
I am also facing the same issue while configuring Legacy interrupt. Have you got any solution to this problem? If you can share your experience it will be graet help:)
Chandra
hi,
can u help me how to use mailbox registers for interrupts
thanks,
What version of Quartus are you using?
Some of the earlier versions (11.0 ....) had problems with interrupts, if you search my posts in the forums you'll find where
I've described the problems I've had.
I think that 12.0 and later versions are working OK.
Nial
hi nial,
am using quartus 12.0
--- Quote Start ---
Environment is:
WindowsXP SP3
Jungo WinDriver
Steps:
--- Quote End ---
Hi yanshine,
I'm wondering if you got through your problems. I am seeing the same issue on my board using a stratixV device. Its 3 years ago, but I'm hoping you have some knowledge to share.
-V
