Ankündigungen
6478 Diskussionen
HPS(Hard Process system) generate Verilog for Simulation
yu1987-08-22
Einsteiger
6.577Aufrufe
Hi All,
 Generate Verilog for Simulation of HPS, But S2F_DATA_WIDTH always 0, mismatch with Setting of HPS. Why or How to solve this mismatch. Thanks
Please see the following picture.
36 Antworten
EBERLAZARE_I_Intel
Mitarbeiter
2.107Aufrufe
Let me try and have the working config changes and upload to you and you check again from your side.
EBERLAZARE_I_Intel
Mitarbeiter
2.096Aufrufe
I am still getting the files ready on my side.
yu1987-08-22
Einsteiger
2.087Aufrufe
  First of all, I want  to make it clear, use for FPGA board is Ok, but for simulation,  HPS used Mentor VIP.
  Are you see in synth or sim directory? At the same time, "HPS to FPGA AXI-4 Master interface" Enable/Data width : 256-bit, then you can compare the file for synth and sim directory, the synth directory is S2F_DATA_WIDTH mismatch with sim directory.   "HPS to FPGA AXI-4 Master interface" Enable/Data width : 128-bit, The compare data width is Match.
Then I found other question,  as following.
AXI4 Don't support AXI_USE_WUSER.
EBERLAZARE_I_Intel
Mitarbeiter
2.075Aufrufe
I only check the files are reflected in the synth folder every time I changed the settings, let me compare them now then for sim.
EBERLAZARE_I_Intel
Mitarbeiter
2.061Aufrufe
I just got back to this issue, and testing your observation on the GHRD, I share the result to you once ready.
EBERLAZARE_I_Intel
Mitarbeiter
2.053Aufrufe
I have tested multiple tests, using the GHRD on Quartus 22.2, after Upgrading the IP, I am able to see the changes correctly for both synth and sim, and for all settings.
Could you try using the GHRD?:
https://releases.rocketboards.org/2021.11/gsrd/agilex_gsrd/agilex_soc_devkit_ghrd_enpirion_QPDS-21.3pro-21.1std.tar.gz
EBERLAZARE_I_Intel
Mitarbeiter
2.046Aufrufe
Do you have any update?
Could you try using the GHRD? The link is in my previous comment.
yu1987-08-22
Einsteiger
2.037Aufrufe
Hi.
  I will try that.
EBERLAZARE_I_Intel
Mitarbeiter
2.022Aufrufe
Any update using the GHRD settings and the hps.v reflected?
yu1987-08-22
Einsteiger
2.013Aufrufe
  I try that, found that, different with us.  Should use plantform gerenate new HPS.
EBERLAZARE_I_Intel
Mitarbeiter
2.006Aufrufe
Did you try to change the settings you mentioned previously just to check if the sim & synth files are in sync when changes all the settings in Platform Designer?
EBERLAZARE_I_Intel
Mitarbeiter
1.991Aufrufe
Can you check my previous respond?
EBERLAZARE_I_Intel
Mitarbeiter
1.977Aufrufe
Any update?
yu1987-08-22
Einsteiger
1.963Aufrufe
   Thanks for your help. I ask FAE, he found the question, and update for me the new Quartus version about 23.2 will solved this question.
EBERLAZARE_I_Intel
Mitarbeiter
1.954Aufrufe
Thanks for the info, I have seen the case and the fix will be in Quartus 23.2, we apologies for any inconvenience in our support we appreciate your feedback.
If no further related questions, could we close the thread?
EBERLAZARE_I_Intel
Mitarbeiter
1.929Aufrufe
I hope that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Antworten
