6270 Discussions
How to build .sof file for Arria 10 fpga dev kit - engineering sample
HungLam
I have one A10 FPGA DEV KIT - 10AX115S-ES
I could not find information about the FPGA device soldered into this kit. I try with 10AX115S2F45I1SG, but not to be successful as this silicon is for production release. (CONF_DONE failed to go high...)
Anyone know silicon used in 10AX115S-ES please share with me. I have quartus pro 19.3, hope I would find it.
Hung
HungLam
I tested with BTS - ES2. It is working, but not sure what is the device name for new bit file compilation.
HungLam
I found silicon name 10AX115S2F45I1SGE2
However, I am not able to find this device in quartus pro device list or progamming list, not sure if this software still suppots this device....
AR_A_Intel
Welcome to INTEL forum. For your information, we normally won’t continue to support ES silicon in newer Quartus version as the FPGA has march into production device.
As a workaround, you can continue to use older Quartus version as shown in the dev kit page.
https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/kit-a10-gx-fpga.html
