6467 Discussions
How to load an Image in RAM of Intel Max 10 FPGA
mamuneeb332
I had used the IP Catalogue in Quartus Prime Lite (22.1) to instantiate a 1-port RAM. Now, i would like to store an Image into it, as far as i know there is only two types of input we can give that is .mif file or .hex file. I am not able to create the Intel Format Hexadecimal File to load in the RAM. Can anyone please help me, how can i convert my image into Intel Format Hexadecimal File that can be loaded. Or is there any alternate solution ?
Thank You.
sstrell
When you say you are not able to create the file, what do you mean?  In Quartus, just select File menu -> New and select to create either a .mif or .hex.  Fill in the table with the RAM contents you want, save the file, then point the parameter editor for the RAM to the file you created.
Ash_R_Intel
What do you mean by 'load an image' ? Image of what ?
As mentioned by sstrell, Quartus gives you option to create a new .mif or .hex file. Did you try it?
Ash_R_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
