6469 Discussions
JTAG PULL UP/DOWN RESISITER
MartinMaa
Hi, I am writing to ask a question about the pull-up and pull-down resistors used in JTAG signals.
If an FPGA has internal pull-up resistors, do I need to add these resistors? If I do need to add these resistors, do they need to be placed close to the programming port, or is there no such requirement?
I would appreciate any information you can provide on this topic.
Thank you for your time and consideration.
NurAiman_M_Intel
Yes, FvM is correct. Diodes and capacitor are more critical. The position of the resistor in your design should be fine.
Aiman
NurAiman_M_Intel
It is recommended to follow the setup in the userguide. For the resistor, it should be put close to FPGA.
Aiman
MartinMaa
Thank you for your reply.
Since my PCB is very small, only 36mmX36mm, there are some difficulties in placing the components.
If the distance is as shown in the figure, will there be a problem? Or is there a maximum allowable length?
482mil (12mm)
FvM
Regarding resistors, I doubt there's a strict close to FPGA requirement because resistance is large multiple of trace impedance. Position of capacitors is more critical, a few centimeters don't matter though.
NurAiman_M_Intel
Aiman
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
