6411 Discussions
Max 10 FPGA unused pin connection
Pavithran_G
    We are using MAX 10 FPGA for our design , We are not using all pins, were we need to connect the unused pin ? shall we keep unused pin in floating ?
Here I am attaching un used pin details
ak6dn
Valued Contributor III
Typically you can specify that unused output/bidir pins can be set to drive a low level out.
And unused inputs you can activate a pullup/pulldown to establish a fixed level on the input if not externally driven.
Pavithran_G
Hello ,
           The given link is not opening its showing some error , can you please share the valid link again .
Pavithran G
AminT_Intel
 We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
