- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hello!
I am following https://ofs.github.io/ofs-2024.2-1/hw/common/user_guides/oneapi_asp/ug_oneapi_asp/ to set up OneAPI for the Agilex 7 I-Series Development Kit (2x R-Tile, 1x F-Tile).
At step 2.5.1 Compile Initialization Bitstreams the command
./build-default-binaries.sh -b ofs_iseries-dk
failed with the output in the attached file.
Regarding the Verilog error, I found this https://www.intel.in/content/www/in/en/programmable/quartushelp/22.1/index.htm#msgs/msgs/evrfx2_veri_opposite_direction.htm. Is there actually an error in ofs_plat_prim_burstcount1_mapping_gearbox.sv or am I doing something wrong?
All tools should be the versions mentioned in the OneAPI ASP Getting Started Guide but the host OS is Ubuntu 24.04.
I would appreciate some help. Thanks!
Felix
Lien copié
- « Précédent
- 1
- 2
- Suivant »
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi @gustifix2,
Thank you for the hold, as the initial issues posted in this thread has been solved.
And notice that you have another posted created for the board related issues mention here.
Hence we could use that post moving forward to make it more clear.
Note: the mention post as followed: https://community.intel.com/t5/forums/forumtopicpage/board-id/fpga-soc-cpld-boards-kits/message-id/29250#M29250
Best Wishes
BB
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
- « Précédent
- 1
- 2
- Suivant »
