Hi, In our old design we have used "EP1K50FI256-2" FPGA, which is not available now (EOL). This FPGA is configured as PPA mode (Passive Parallel Asynchronous).
While searching "ACEX® 1K" migration path we found below link: https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/component/2017/what-is-the-replacement-device-for-eol-parts.html
Which says MAX V device is compatible to ACEX 1K device.
1. Whether MAX V device support PPA mode. If yes please share us Application note.
2. If not please suggest PPA mode next available FPGA.
regards
Srinivasa.
Hi SThat5,
MAX V device did not support PPA mode.
However, you can configure the MAX V device in passive serial (PS) or fast passive parallel (FPP) scheme.
You may refer to following user guide for more details.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
Cheers
