6472 Discussions
Please support DK-DEV-3C120N new version? All sample code about RAM is fail
I got a new version DK-DEV-3C120N, but I found SDRAM and SRAM have been replaced with new component.
And I can’t get some more detail information about that, andall sample code about RAM can’t be run.
Can you give me some advice and help me?
The following is text above these chips:
DDRRAM X 4: 3IH22 D9LHT 6RDR
DDRRAM X 1: 3RG22 D9LQG DTFD
SRAM: 3SB47 PW755 GC9B
Unfortunately the latest installation kit is only up to Quartus version 11.1
ftp://ftp.altera.com/outgoing/devkit/11.1/cycloneiii_3c120_dev_kit-v11.1.0.exe
does this work?
It does not work!
I have tried every sample code with every version.
I am sure, the SRAM and SDRAM have been changed.....
If you burn factory binary file to the board(new version with new sram and new ddr), the item about memory test will fail when you run "BoardTestSystem.exe".
And the older version DK 3C120 is Ok!!!
Unfortunately I can't help much here. You can try contacting Altera support to see if there is any updated installer, but I really doubt so... :(
