6468 Discussions
Qsf file for emif ip arria 10 SoC development kit
srinivasan
Can anyone share the qsf file(pin assignment) for DDR4 EMIF IP using arria 10 SoC development kit(x72 fpga pin).
sstrell
Assuming this is the kit you're talking about, all the files you'll need are here including example designs for the EMIF:
https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/arria-10-soc-development-kit.html
srinivasan
Hi strell,
 Thanks for your replay,
I got this link already,but I am not getting specific  fpga emif design file the link which you have shared,there is only HPS EMIF design file..
As of now , mainly i need QSF file for FPGA EMIF(DDR4 memory)..if you get that....please share it..
yoichiK_intel
please refer to the attachment.   change *txt to *qsf, could not attach qsf file.
srinivasan
Thanks for sending the files...
Actually, arria 10 soc part number is 10s066N3F40E2SG...but in ed_synth.txt files they have mentioned 10s066N3f40I2SG...which i need to choose?
But in EMIF IP GUI i am selecting fpga development DDR4 HILO connector(x72)...If I select this , it automatically taking below part number...
arria 10 device:10s066N3f40I2SG
yoichiK_intel
sorry ,attached wrong file. Here is the right one.
srinivasan
Ya got it..thanks..
Which clock should I connect to signal tap analyser??
Whether I need to connect pll_ref_clock or clk_50mhz
yoichiK_intel
pls use pll_ref clock for STP clocking.
srinivasan
Can u please share your working EMIF DDR4 traffic generation project for arria 10 SoC development kit....
