6474 Discussions
Ram usage of Local Memory Arrays in OpenCL for FPGA
bruhay
I wrote a simple code in OpenCL for FPGA board. I use DE10 nano shared-only board and Intel SDK 18.1 . The main problem is too much Ram consumption. the HTML report mainly shows the problem in Local memory arrays. In an ND-range kernel this problem gets even worse!
Another problem is: there is a compiler warning for all Local arrays which is:
(Aggressive compiler optimization: removing unnecessary storage to local memory)
By the way, In the LOOPS ANALYSIS tab there is II : ~1 and in Details pane it mentions:
(II is an approximation due to the following stall-able instructions: Load Operation #no, Store Operation #no). How can I resolve it and reach the exact 1 for II ?!!
