6454 Discussions
Running batch file of ADC on DE1 SoC from demonstration folder
qizilbash
Whenever I try to execute batch file of ADC stored in the FPGA folder of Demonstrations, it gives me an error "The system cannot find the path specified". What should I do to make this work?
mabdrahi
Hi qizilbash,
Thanks for contact us,
May i have the following detail?
1) OS version (Window/Linux)
2) Quartus version is 22.1 std?
3) Project reference (link/documentation and which step do you encounter error)
Thank you,
Aliff
qizilbash
So my pc is running on windows.
I have quartus prime lite with 22.1 std version.
The project is given in DE1 SoC user manual in Examples for FPGA with the name of ADC reading.
https://community.intel.com/cipcp26785/attachments/cipcp26785/fpga-soc-cpld-boards-kits/16133/1/DE1-SoC_User_manual_revf.pdf
I encounter the problem whenever I run the batch file and it says "system cannot find the path specified" and it fails to run NIOS II console window.
mabdrahi
I will try to reproduce at my end
i will come back to you soon
qizilbash
qizilbash
Actually got it working. I downgraded my quartus to 17.0 and it works perfectly fine.
mabdrahi
You need to open the makefile and check the directory set there, can you run any other designs?
This design from terasic which we will recommended to get help from there.
BUT
from our side we can provide best support. Try to run helloworld example with makefile.
mabdrahi
Any update at your end?
qizilbash
mabdrahi
I will close the case
