Signals in VHDL
Razvan1203
I need to convert a C function to a vhdl code. In the C function there is an array uint32_t a[20] and I convert it to a signal in vhdl (type array_type is array (0 to 19) of std_logic_vector(31 downto 0); ). I made a FSM for this implementation and the problem is when I try to assign some values to the array (a(i) <= some_value;),
However, when I check in simulation (waveform), all values remain 'X', even after a few clock cycles.
What could be the reason for this behavior?
Additional details:
  • i is properly incremented.
  • The value assigned (some_value) is well-defined (not 'X').
  • The FSM transitions correctly through states.
  • I have tried using an initialization process for a, but still get 'X'.
Any ideas on what could be wrong?
sstrell
Really need to see the design (at least some code) and the testbench.
ShengN_Intel
Possible to provide the design for review?
Sheng
ShengN_Intel
Does the problem being resolved? Any further update on the design providing?
Sheng
