6472 討論
Simulating by ModelSIM on quartus|| 9.0 - XOR function bus_signals error in verilog file
Savino
初學者
715 檢視
Good evening everyone, for several hours I have been running into a problem using quartus|| 9.0 and ModelSim.
I have created a very simple project with a bus input and a bus output, and an XOR function inside. The program synthesis is successful and so is the simulation. Unfortunately, as soon as I try to simulate the program via ModelSIM an error appears. Basically:
- given the program written and compiled with a .bdf file
- I create the .hdl file (so I delete the .bdf file)
- as soon as I launch the RTL simulation, a syntax error appears in the file automatically created by quartus|| as follows:
assign out = in[29:0] ^ {in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in}[30];
if I try to perform the XOR operation between non-bus data (single data) I have no error. It seems that the XOR function between multiple data such as data buses generates this error. Is there a solution?
I attach the project.
標籤 (1)
0 積分
1 解決方案
ShengN_Intel
員工
609 檢視
Hi Savino,
I misunderstood the situation. As mentioned by sstrell, the input must be same width. Using same width will be no problem.
You're using different width, that's why causing the bug.
Sheng
在原始文章中檢視解決方案
5 回應
sstrell
榮譽貢獻者 III
641 檢視
An XOR between a bus and a single signal makes no sense.  The bus widths must match to perform a bit-by-bit XOR operation.
ShengN_Intel
員工
625 檢視
Please change this assign out = in[29:0] ^ {in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in}[30]; to this assign out = in[29:0] ^ in[30];
Sheng
Savino
初學者
620 檢視
Hi, I tried all the combination without succes and at the end i used more xor gate for each single data, like attached and i fixed the issue but if is possible do the xor operation in one shot for me is better (like at beginning working with bus data)
ShengN_Intel
員工
610 檢視
Hi Savino,
Sheng
Savino
初學者
550 檢視
okay, tks for fdk
回覆
