6345 Discussions
Source Synchronous Interface Output Constraint
Sahil_Honeywell
I am trying to write timing constraints for FPGA - SDRAM communications. I know as per Intel documentation, the formulas are:
output maximum delay  = maximum trace delay for data + tSU of external register - minimum trace delay for clock
output minimum delay = minimum trace delay for data  – tH of external register - maximum trace delay for clock
Now, For my design I have the maximum & minimum trace delays from PCB design of the board (considering 16 data lines between FPGA & SDRAM. I also have the tSU from SDRAM data sheet.
My questions are:
1) To calculate the board delay, I looked at the data (D0-D15) trace length between FPGA & SDRAM, using the PCB designer tool. Using the trace length and other parameters, I calculated the min & max board delay between FPGA and SDRAM. Is that the right way of doing it?
2)  How can I calculate the minimum & maximum trace delay for the clock? There is only (clock) line going from FPGA to SDRAM, so it will have only 1 delay value. How do I calculate min and max for the clock trace?
Please advise
Sahil
IntelSupport
Community Manager
1. Generally is yes. Calculating the minimum and maximum board delays between the FPGA and SDRAM based on the trace length is a good starting point and right way to do.
2. The clock's lowest and maximum trace delays can be determined similarly to how the data lines are. The lowest and maximum trace delays for the clock can be calculated using the PCB designer tool and the measured trace length of the clock line. You can also take into account additional elements like the skew between the clock and data lines, the transmission delay through any clock buffers or inverters, and any additional circuits that might impact the clock delay.
SyafieqS
Let me know if there is any concern on this.
SyafieqS
 As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
