TCCS and ALTDDIO_OUT
MYota1
I am using ALTDDIO_OUT channels in Cyclone 10 LP and map them onto true LVDS pins. Is there a way to get the TCCS analysis between the channels ?
My other question: Does the TCCS that is defined in the datasheet, for example for the true LVDS, depends on the IP core being used ?
sstrell
TCCS is device-specific, not IP specific. You can run the TCCS report in the Timing Analyzer in Quartus to get the value without having to look it up.
#iwork4intel
MYota1
Thank you. However when I run the Timing Analyzer to get the value of TCCS I get: "No dedicated SERDES Transmitter circuitry present in device or used in design".
Rahul_S_Intel1
Hi ,
Timing Analyzer provides the transmitter channel-to-channel skew this is serdes not for normal IO
>> device specific , the max value can be find in the data sheet for example page no 38 for the Cyclone 10 GX
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-10/c10gx-51002.pdf
MYota1
