6466 Discussions
TI USB GUI to access LMK04828 on Arria 10 SoC Development kit
SoC_Developer
I am using Arria 10 SoC development kit. I want to use on board Clock cleaner IC LMK04828. As per the schematic diagram, settings for the Clock cleaner can be done using USB port (Connector J47). I Tried using "TICS Pro" to configure the Clock cleaner but option to access to FTDI USB is not enabled and it is not connecting to the SoC Development kit. It is supporting only USBTOANY interface.
If any software is already available to access LMK04828 on Arria10 SoC Development kit, Please inform me the link to download the software.
Thanks in advance.
Deshi_Intel
HI,
Unfortunately Intel doesn't provide customization support for 3rd party chip vendor support.
There is only limited control to access certain chip on board.
I can see that we have clock controller gui.exe to control the output frequency of certain SI clock generator chip on board. Maybe you can modify your design to switch the clock source pins if you need to change to not default clock frequency usage.
dlim
