6472 Discussions
Unable to program my .sof file into the Stratix10 Development Board.
NLewi3
Programming my design.sof onto the Stratix10 Development Board the Progress Bar stops at 9% and I received the following 3 messages: "Device has stopped receiving configuration data 18950." "Error message received from device: Device is in configuration state 18948." "Operation failed 209012."
YuanLi_S_Intel
Hi Nik,
This might be due to on-board switches or programming cable. Are you using USB Blaster II? If it so, can you try to change the cable's TCK frequency to 6MHz in Quartus Programmer? Also, can you try to change all the switches to default position on the board?
YL
NLewi3
After further investigation I am able to load the ‘btsd_config.sof’ for the Stratix 10 Development Board. However, I am unable to generate a .sof file that I can load into the Stratix 10 Development Board. I have a very simple design, an input clock driving a counter which is attached to some output LEDs. The .sof that is generated stops loading at 13% and the error “Device has stopped receiving configuration data. Error message received from device: Device is in configuration state. Operation failed”. I am at a loss as to what the problem could be??? Thanks, Nik
NLewi3
All switches are in the default position with the same result. Tried 6MHz, same result. I can program the 'bts_config.sof' (this .sof is supplied with the Development Board) without any problem. What setting am I missing to generate a proper .sof that I can program into the Startix 10???
Nik
YuanLi_S_Intel
Hi Nik,
Can you check if you are selecting the correct device OPN in Quartus design?
YL
