5693 Discussions
Using Altera reserved I/O pins by an Altera IP
Gyud0
hey,
I'm using Altera IP that requires I/O pins that also reserved for Altera so I got Fitter's Quartos errors such as:
Error(176310): can't place multiple pins assigned to pin location Pin_E2 (IOPAD_X0_Y36_N7)
Info(176311) : pin flash_nce is assigned to pin location Pin_E2
Info(176311) : pin ~AlLTERA_FLASH_nCE_nCSO~ is assigned to pin location Pin_E2
how can I overcome thee problems?
Thank you
sstrell
What IP? What device? More detail needed.
#iwork4intel
Gyud0
The IP is Parallel Flash Loader while the device is Cyclone 3.
these are the IP's ports:
entity parallel_flash_loader is
port (
pfl_flash_access_granted: in std_logic;
pfl_nreset:in std_logic;
flash_addr: out std_logic_vector(22 downto 0);
flash_data:inout std_logic_vector(15 downto 0);
flash_nce: out std_logic;
flash_noe: out std_logic;
flash_nwe:out std_logic;
pfl_flash_access_request:out std_logic
end entity parallel_flash_loader ;
ShafiqY_Intel
Hi Gyud0,
Error(176310) because of you assigned two or more pins to the specified location, but the Fitter cannot place all the pins in that location.
Below is solution you can try:
If the conflict arises from location assignments in the current project, delete or change the location assignment of one or more of the pins. If the pin location assignments come from one or more imported design partitions, delete or change the location assignment (possibly using the Virtual Pin assignments) in the lower-level designs, re-generate the Quartus Prime Exported Partition File(s) (.qxp) , and re-import.
