6472 Discussions
cyclone III: LCD Help needed
I have been trying to program the lcd on the cyclone iii but i don;t get any respone...i even probed the pins to check if what the pins were what they should be and most of the data pins just stay on high.........The program i wrote is shown below: and i assign the pinouts according to the reference manual.....help is urgently needed............
module lcd_display (clk,user_dipswitch2,user_dipswitch3,mydata,lcd_rs, lcd_rw, lcd_e, lcd_code);
input clk;
input user_dipswitch2;
input user_dipswitch3;
input [7:0] mydata;
integer count;
reg busy_flag;
//reg [6:0] lcd_code
output reg lcd_rs ;
output reg lcd_rw ;
output reg [7:0]lcd_code;
output reg lcd_e;
initial
begin
busy_flag <= lcd_code[7];
lcd_rs <= 0;
lcd_rw <= 0;
lcd_e <= 0;
count <= 0;
end
always @ (posedge clk )
begin
lcd_rs <= 0;
lcd_rw <= 1;
if (user_dipswitch2 && !busy_flag) //initialize lcd
begin
lcd_rs <= 0;
lcd_rw <= 0;
lcd_e <= 1;
case (count)
0: begin //function set
lcd_code <= 8'b00111100;
count <= 1;
end
1: begin // Display on
lcd_code <= 8'b00001111;
count <= 2;
end
2: begin // Display clear
lcd_code <= 8'b00000001;
count <= 3;
end
3: begin // Entry mode set
lcd_code <= 8'b00000111;
count <= 4;
end
4: lcd_e <= 0;
endcase
end
else if (!user_dipswitch2 && !busy_flag && user_dipswitch3)
begin
lcd_rs<= 1;
lcd_rw <= 0;
lcd_e <= 1;
lcd_code = 8'b11100011;
end
end
endmodule
This kind of LCD is extremely slow, what is your clock frequency?
commands like "clear screen", take to execute even 40 ms.
Did you simulate this module?
thanks for the reply....am fairly new to verilog...am not familliar about how to introduce the timing into the hardware......am using 50MHz
