6466 讨论
error message: can't fit into the design
AKAYA
新手
6,396 次查看
i am trying to use QSPI controller along with ALTPLL. But during compilation it gives an error. Am using pll configuration with 2 clocks C0 and C1.
the error message is:
Error (176394): Can't fit 2 PLLs in the device -- only 1 PLLs are available
Info (176395): Location PLL_3 cannot be used due to package or device migration constraints
Info (176395): Location PLL_4 cannot be used due to package or device migration constraints
Info (176395): Location PLL_2 cannot be used due to package or device migration constraints
can someone please suggest how to overcome the error
0 项奖励
1 解答
AnandRaj_S_Intel
3,237 次查看
​Hi,
I have not modified the design which you have shared in previous post attachments.
  1. You can add Qspi and PLL in Qsys system(onchip.qsys/onchip.qip) and remove the pll.qip file from project and  onchip.qip set as top level entity and compile. Attached the file do pin assignment and other configuration as per you requriment
For RSU design example (QSPI &PLL) look into design stores or follow an741 or check below video links
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an741.pdf
https://fpgacloud.intel.com/devstore/platform/?search=RSU&acds_version=any&family=max-10search for reference design.
https://www.youtube.com/watch?v=Qgwd8ftiTZc
https://www.youtube.com/watch?v=bAyqWWm1yLU
https://www.youtube.com/watch?v=r3wcgr3LmjA
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand
在原帖中查看解决方案
0 项奖励
20 回复数
JOHI
新分销商 II
3,221 次查看
A single pll can have multiple outputs depending on the frequencies you want to generate. Did you consider this option?
Br.
Johi.
0 项奖励
AnandRaj_S_Intel
3,221 次查看
Can i know which FPGA device(P/N) are you using?
This error say it all, your device support only 1 PLL but you are using 2 PLL.
To solve you can follow the suggestion given by @JOHI​ or change the device as per design requirement.
Please check below thread with similar issues which may help you.
https://forums.intel.com/s/question/0D50P00003yyTYJSA2/max-10-using-two-altpll?language=en_US
ARS
0 项奖励
AKAYA
新手
3,221 次查看
thanks for the reply
am using 10M25SAE144C8G device. it shows a resource count of 4
I can't change the device. is there any other option....
0 项奖励
AnandRaj_S_Intel
3,221 次查看
Hi AKAYA,
The device 10M25SAE144C8G  is having only 1 PLL.Please check the image.
You can follow the suggestion given by @JOHI​ , use single PLL with multiple outputs depending frequency requirement.
Anand
0 项奖励
AKAYA
新手
3,221 次查看
thanks for the reply...
but can you tell me what exactly is the reason for the error...
I have used an ALTPLL IP with C0 as the compensated output....
0 项奖励
AnandRaj_S_Intel
3,221 次查看
Hi Akaya,
Fitter cannot place the specified node at the specified location which has been disabled to drive to the clock networks because the current package does not support it, or because it cannot be used when device migration is selected.
I guess, Initial design was for some other device from same family 10M25 which had 4-PLL and you have migrated to 10M25SAE144C8G which is having only 1 PLL because of which you are having error.
If you are using 10M25SAE144C8G device you can have 1-pll with 4-output max.
Check .qsf file for lines like set_location_assignment PLL_{number} -to "{path}"
set_location_assignment PLL_0 -to "{path}"
set_location_assignment PLL_1 -to "{path}"
set_location_assignment PLL_2-to "{path}"
set_location_assignment PLL_3 -to "{path}"
have set_location_assignment PLL_0 -to "{path}" and remove other line set_location_assignment PLL_1/2/3 -to "{path}" and Delete db and incremental_db folders and recompile the design and check.
Anand
0 项奖励
AKAYA
新手
3,221 次查看
thank you for the reply....
I didn't change the device, am using the same device..
in the .qsf file does not contain any line like set_location_assignment PLL_{number}
can someone suggest me how to solve this
0 项奖励
AnandRaj_S_Intel
3,221 次查看
​Can you share the project?
0 项奖励
AKAYA
新手
3,221 次查看
thanks for the reply....
I am attaching the project here...
the QSYS is in the folder RSU--> OnChip.qsys
0 项奖励
AKAYA
新手
3,221 次查看
am not able to attach the project here
0 项奖励
AnandRaj_S_Intel
3,221 次查看
  1. You have to delete the db and incremental_db folders and regenerate qsys and mega-wizard pll system and recompile the design and check.
I got your project, i have just followed above steps which solves the issue and Attached project for your reference. i have used quartus 17.0 std.
If you are still facing problem use latest version of quartus tool.
Anand
0 项奖励
AKAYA
新手
3,221 次查看
but the qsys file des not contain any ALTPLL or QSPI Controller....
0 项奖励
AnandRaj_S_Intel
3,221 次查看
​duplicate
0 项奖励
AKAYA
新手
3,221 次查看
0 项奖励
AnandRaj_S_Intel
3,221 次查看
​Duplicate
0 项奖励
AnandRaj_S_Intel
3,221 次查看
0 项奖励
AnandRaj_S_Intel
3,221 次查看
​Duplicate
0 项奖励
AnandRaj_S_Intel
3,221 次查看
​duplicate
0 项奖励
AnandRaj_S_Intel
3,238 次查看
​Hi,
Anand
0 项奖励
AKAYA
新手
3,115 次查看
the project is compiling now without any error...
thanks for the help
回复
