aoc: First stage compilation completed successfully.
Compiling for FPGA. This process may take a long time, please be patient.
Error (170012): Fitter requires 5692 LABs to implement the design, but the device contains only 4191 LABs
Error: Cannot fit kernel(s) on device
Based on my knowledge, you may need to remove some logics to optimize and fit your design.
Is there any other error during your compilation?
Thanks!
I have optimized my kernel code and it work now.
The other error when I try to compiling as emulator the following error was generated.
aocl-clang: error: unable to execute command: posix_spawn failed: No such file or directory
aocl-clang: error: linker command failed due to signal 1 (use -v to see invocation)
aocl-clang: note: diagnostic msg: Please submit a bug report to http://llvm.org/bugs/ and include command line arguments and all diagnostic information.
aocl-clang: note: diagnostic msg: Error generating preprocessed source(s) - no preprocessable inputs.
Error: Optimizer FAILED.
Refer to My_Kernel/My_Kernel.log for details.
Helo,
I could not find the exact workaround regarding your error, it could be that there is a conflict of a symbolic link that is wrongly represented, can you check the below discussion if it is related to yours?:
Thank you!
Really, I appreciate you for great help.
It is working for me.
