6471 토론
how to download configuration code to Cyclone 10 dev kit board for customer's power-up configuration
YYang79
초급자
2,843 조회수
I have a Cyclone 10 development kit board: DK-DEV-10CX220-A.
It works well with BTS. I need to download my own configuration code either to EPCQ-L(ASx4) or to the NOR flash memories on the board to boot up the FPGA at power up. I have tried the EPCQ-L programing but it fails. For the NOR-Flash, i don't know how to convert my sof file to the one fits the memory type. Is there any one who can help me? VERY Appriciated!!!
0 포인트
17 응답
NurAiman_M_Intel
2,827 조회수
Kindly share the screenshot of the error and also photo of the board as we will need to see if the switch was correctly set up.
You can also check the error if you are using Quartus pro, enter the error code and press enter:
https://www.intel.com/content/www/us/en/programmable/quartushelp/current/index.htm#msgs/msgs/msgs.htm
Aiman
0 포인트
YYang79
초급자
2,824 조회수
Hi Aiman,
i have contacted you before. My issue is still unsolved. per you request i attached the pictures.
0 포인트
NurAiman_M_Intel
2,808 조회수
Apologize for the delay in response.
JIC programming failure might be due to TCK frequency of the USB blaster II. Try to change it to 6MHz.
On top of that, please ensure to change switch to AS switches. Can refer userguide below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-c10-gx-fpga-devl-kit.pdf
Aiman
0 포인트
YYang79
초급자
2,803 조회수
Would you please let me know how to change it to 6MHz?
0 포인트
NurAiman_M_Intel
2,797 조회수
You can refer to download cable II userguide below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_usb_blstr_ii_cable.pdf
Aiman
0 포인트
YYang79
초급자
2,780 조회수
Hi Aiman,
Following your instruction, I reconfigured the TCK frequency (though i don't know if  i did correctly). It still fails. Attached please find out the screen shot for you.
0 포인트
NurAiman_M_Intel
2,761 조회수
Please check if the device chose in the quartus->assignment->device->device/board is the correct device as per the dev kit.
Aiman
0 포인트
YYang79
초급자
2,758 조회수
0 포인트
NurAiman_M_Intel
2,741 조회수
Perhaps you can try this steps:
  1. Auto detect device, right click the device and add bitstream into it
  2. Remove the empty device(just as I shown before in the red box)
  3. Hit program
On top of that, try to check whether SOF file can program or not to minimize the scope or error. If can, then there is possibility the JIC file has problem. Can try on the other version as well to check if it is version dependent.
Aiman
0 포인트
YYang79
초급자
2,737 조회수
I did according to your suggestion. It did not work.
I can down load my code via JTAG by using SOF file to FPGA directly after power up. It tells us the code is working. The issue is just I could not permanently put it into the FLASH so as not to be able to boot the FPGA at power up.
I've tried revision of 17.1 and 19.1 of Quartus Prime Pro. Neither works.
0 포인트
NurAiman_M_Intel
2,734 조회수
Perhaps there is issue with JIC.
Is the flash device selected correct during JIC creation and have choose correct configuration scheme in quartus?
Aiman
0 포인트
YYang79
초급자
2,729 조회수
I generated it just following the manual. Is there any hidden point i should pay attention to? It's supposed to be very straightforward, right?
0 포인트
yasuhito
초급자
2,716 조회수
OnBoard USB Blaster of DK-DEV-10CX220-A has Two JTAG devices.
1st device is CFG MAX10(10M08SA) for PFL.
2nd device is Cyclone 10 GX(10CX220Y).
How to
(1) Open Programmer.
(2) Click "Auto Detect". You can find "10M08SA" and "10CX220Y".
(3) Select "10CX220Y"
(4) Click "Change File". and Open .jic file.
(5) Check "Program/Configure".
(6) Click "Start".
OK?
0 포인트
YYang79
초급자
2,665 조회수
Thank you for your response. Yes. That was the procedure that i did.
0 포인트
yasuhito
초급자
2,651 조회수
"10M08SA" is not included in the above picture "SLF_error.png".
Do not delete "10M08SA".
It looks like an attachment picture.
0 포인트
NurAiman_M_Intel
2,598 조회수
Hi YYang79,
Is there any update for this case? Else, I will proceed to close this case.
Aiman
0 포인트
YYang79
초급자
2,596 조회수
Just let you know, this issue has not been solved yet. I have no idea why. The dev kit board to me is totally a garbage now! A big loss to me.
0 포인트
응답
