6472 Discussions
i need to know about the reading data into the UFM of the max10 FPGA
AKAYA
In my project, i have two application code, and only one .pof file. I need to read both the application code using the same .pof file so that it become flexible to read any application code into the UFM memory only by dumping the .pof file only once and need not be dumped again and again. The data should be read through the Serial terminal using UART.
Can someone tell me if we can do this.....
KINDLY WAITING FOR THE REPLY
GuaBin_N_Intel
Are you trying to boot up with one option to select different applications from UFM memory?
