- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi snehal_p
I found that the DE1SOC has a multiplexer for the I2C.
Could you try setting the HPS_I2C_CONTROL (GPIO48) high before trying out the i2c command?
Jingyang, Teh
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Jingyang,
PFA screenshot of the debug console, 68h is the address for the rtc breakout board. It seems that it is detecting rtc and also returns value for i2cget command but when executing rtc application it returns wrong values.
PFA rtc.c code.
snehal_p
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Snehal
I took a look at your source code and the screenshots.
It seems like the i2c is working as the log shows that the application is able to connect to the i2c device.
A little comment on the main function, the calling of the "rtc_get" and "rtc_set " there are no pointers being passed into those function.
To interact with the rtc module the i2c you would need to set the device register first.
You might need multiple set and get function call:
"i2cset- 1 0x68 0x6"
"i2cget -1 0x68 0x00"
Below is a snippet from the datasheet of the DS3231.
Data transfer from a master transmitter to a slave receiver. The first byte transmitted by the master is the slave address. Next follows a number of data bytes. The slave returns an acknowledge bit after each received byte. Data is transferred with the most significant bit (MSB) first.
Data transfer from a slave transmitter to a master receiver. The first byte (the slave address) is transmitted by the master. The slave then returns an acknowledge bit. Next follows a number of data bytes transmitted by the slave to the master. The master returns an acknowledge bit after all received bytes other than the last byte. At the end of the last received byte, a not acknowledge is returned. The master device generates all the serial clock pulses and the START and STOP conditions. A transfer is ended with a STOP condition or with a repeated START condition. Since a repeated START condition is also the beginning of the next serial transfer, the bus will not be released. Data is transferred with the most significant bit (MSB) first"
Jingyang, Teh
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Jingyang,
Thanks!
PFA screenshot of debug console. Can you please help me understand the output of i2cdetect as UU.
I'm also facing issue with .dtb file, PFA debuglog , after switching on the system it works well but after I switch it off and on again it hangs after Starting kernel. Can you help me diagnose the issue
Thanks and regards,
snehal_p
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Snehal
For the RTC Module did you associate it to a kernel driver?
From the starting logs that the rtc is being registered under the kernel.
"[ 1.217136] rtc-ds1307 0-0068: setting system clock to 2000-04-24 05:56:41 UTC (956555801)"
That is why the address is showing UU when you are using the i2cget command.
Regarding the kernel hang, does it happen all the time?
I see that the uboot version is quite an outdate one. I would suggest you to use the latest uboot version(U-Boot 2022.04).
Jingyang, Teh
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Jingyang,
Thanks, RTC detect sorted. but not able to read the correct date and time.PFA c code
Kernel hang is still the issue at times, what could be the probable reason.
Also can you help with the example code for RS232 with flow control.
snehal_p
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Snehal
I am not too sure on what could cause the kernel hang but I would suggest you use a newer version of the linux kernel.
From my experience with RS232, I have not seen a software flow control for RS232.
The RS232 got lots of hardware flow control that we could utilize.
I could be wrong on this statement.
However I managed to find this RS232 example from the Intel website.
Jingyang, Teh
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Jingyang,
RS232 with hardware flow control IC I'm using MAX3241EEAI+T.
If you can help me with the example code.
snehal_p
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Jingyang,
Can you please help me with the project folder or uart.c code mentioned in the document.
snehal_p
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Snehal
Sorry that we do not have an example for the RS232 with flowcontrol.
Jingyang, Teh
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi
Any update on this?
Jingyang, Teh
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Jingyang,
I'm still facing issue of kernel hang, I tested different sd card images and could conclude that it has to be a .dtb file as this issue is only with the sd card images in which I2C is enabled for RTC interface, others are working OK
PFA .dtb files with rtc and without rtc. Can you please help me with the issue.
snehal_p
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Snehal
Could you switch the files in between the sd card?
I take a look of the dtb file and the only changes are enabling the i2c.
I dont see it could cause the kernel to hang.
Jingyang, Teh
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Snehal
Is the kernel hang issue still occurring after swapping the sdcard?
Jingyang, Teh
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi
Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
