local error in Transcevier
druva1
新分销商 I
997 次查看
I have a local error in my rx_parallel data "0x0100009c". I set up an arria 10 transceiver with a reset controller and atx_pll for a 10GBase-R protocol so I can send 64 bits of data.
I set up a simple state machine that send idle until the system is ready, and then it starts transmitting data of a normal counter. But every x amount of bits I get a local fault error 0x0100009c inserted in my rx_parallel.
If you have any tips that would help me fixt this error I would appreciate it.
0 项奖励
1 解答
CheePin_C_Intel
980 次查看
Sorry for the delay. As I understand it, you have some inquiries related to the rx_enh_data_valid de-assertion in your simulation. For your information, when the rx_enh_data_valid is de-asserted, it indicates that the RX parallel data is invalid and you should ignore/discard this data. Your downstream logic should accept RX parallel data with rx_enh_data_valid = 1.
Please let me know if there is any concern. Thank you.
Chee Pin
在原帖中查看解决方案
0 项奖励
2 回复数
CheePin_C_Intel
981 次查看
Chee Pin
0 项奖励
CheePin_C_Intel
941 次查看
As I understand it, it has been some time since I last heard from you. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
0 项奖励
回复
