Ankündigungen
6478 Diskussionen
quartus sythesize question
SamPF
Einsteiger
988Aufrufe
when I design a project, there are many modules in this project, in one of the modules (not the top module) I mark the wrong io type (for example: input tag to output), and in the module This io doesn't have any value assigned just flags error and then I synthesize it in quartus successfully but in real application it doesn't work my question is:
How can I set quartus to find this error during the sythesize phase?
BR,
Sam PF
Beschriftungen (1)
8 Antworten
FvM
Geehrter Beitragender II
946Aufrufe
perhaps I didn't yet understand the example. I believe you'll get compilation errors in most cases.
Connecting an output port to a signal that is expected to drive an input will give a multiple driver error, because the signal is already driven. The reverse situation won't cause an error in the upper hierarchhy level, just leave an undriven signal. But in the lower hierarchy  (module implementation) level, you can't drive the erroneously defined input without causing an error.
So you are apparently talking about a consistently designed module that is connected erroneously in the upper hierarchy. I think confusing in- and output ports is only one of many possible wrong connections and no particular case.
You'll want some kind of verification, e.g. with a simulator. It an easily mark undriven signals.
Frank
SamPF
Einsteiger
915Aufrufe
Hi, FvM
First of all thanks for your reply, I'll give you an example to describe the problem I'm having.
You can see the Main_Seq module, PWRGD_a is the input, but I marked it as output. The final result b_EN will become high during simulation, which is also successful in quartus sythesize, but b_EN will not become high in the actual synthesis circuit.
Do you know how to verify this problem or use some settings in sythesize to avoid this problem?
module top(
    output  a_EN,
    output  b_EN,
    input   PWRGD_a,
    input   POWER,
    input   CLK_2M
// Rst Control
wire    Rst;
assign  Rst = POWER ? 1'b1 : 1'b0;
// sync signal
wire    w_PWRGD_a;
sync sync_inst(
    .clk(CLK_2M),
    .Rst(Rst),
    .iSync(PWRGD_a),
    .oSync(w_PWRGD_a)
Main_Seq main_seq_inst(
    .clk(CLK_2M),
    .Rst(Rst),
    .a_EN(a_EN),
    .b_EN(b_EN),
    .PWRGD_a(w_PWRGD_a)
endmodule
module sync(
    input   clk,
    input   Rst,
    input   iSync,
    output  oSync
reg rSync;
reg [10:0] iSync_delay;
assign  oSync = rSync;
always @(posedge clk) begin
    if(!Rst) begin
        rSync <= 1'b0;
        iSync_delay <= {11{1'b0}};
    end
    else begin
        iSync_delay <= {iSync_delay[9:0], iSync};
    end
end
begin
    if(!Rst) begin
        rSync <= 1'b0;
    end
    if(~|iSync_delay)
    begin
        rSync <= 1'b0;
    end
    if(&iSync_delay)
    begin
        rSync <= 1'b1;
    end
end
endmodule
module Main_Seq(
    input   clk,
    input   Rst,
    output  a_EN,
    output  b_EN,
    output  PWRGD_a
reg a_EN_ff;
reg b_EN_ff;
assign a_EN = a_EN_ff;
assign b_EN = b_EN_ff;
    if(!Rst) begin
        a_EN_ff <= 0;
        b_EN_ff <= 0;
    end
    else begin
        a_EN_ff <= 1;
        if(PWRGD_a) begin
            b_EN_ff <= 1;
        end
    end
end
endmodule
`timescale 1ns/1ns
module tb_top;
reg clk;
parameter clk_period = 500;
initial begin
    clk = 1'b0;
end
wire a_EN;
wire b_EN;
reg PWRGD_a;
always @(clk)
    #(clk / 2.0) clk <= !clk;
reg POWER;
initial begin
    POWER = 1'b0;
    PWRGD_a = 1'b0;
    #(1000000) // 1ms
    POWER = 1'b1;
end
always @(posedge a_EN & POWER) begin
    PWRGD_a <= 1'b1;
end
top top_inst(
    .a_EN(a_EN),
    .b_EN(b_EN),
    .PWRGD_a(PWRGD_a),
    .POWER(POWER),
    .CLK_2M(clk)
endmodule
BR,
SamPF
sstrell
Geehrter Beitragender III
921Aufrufe
Showing your code would also be helpful to see what is happening.
sstrell
903Aufrufe
You're not seeing an issue because you have an intermediary wire, w_PWRGD_a, so you're never connecting the output of Main_Seq to top.  The names can be the same in different levels of hierarchy.
As for why b_EN goes high in simulation and not in hardware, that's not as clear unless I put it into Quartus.
ShengN_Intel
Mitarbeiter
811Aufrufe
In STP, I'm seeing b_EN high when using input PWRGD_a in Main_Seq.v. While seeing b_EN low when using output PWRGD_a in Main_Seq.v. I think the actual synthesis circuit result is the correct one because need input PWRGD_a to make b_EN high as b_EN depends on the if(PWRGD_a) begin.
However, I'm seeing same result (b_EN high) for both situation in simulation. I'll further confirm with the internal engineering team.
Sheng
SamPF
Einsteiger
763Aufrufe
Hi ShengN
You are right because this is a real problem we have in real systems, when we simulate everything is correct and we load to FPGA it does not work, so the synthesized circuit is correct, but how do I get this in simulation The problem is what we care about, so hopefully you can tell me what I can do in the simulation to prevent this problem, thanks.
BR,
Sam
ShengN_Intel
Mitarbeiter
684Aufrufe
I had reported the problem. Will get back to you once any further feedback.
ShengN_Intel
Mitarbeiter
454Aufrufe
The problem is planned in 25.1std. I would suggest you to stick with the result of signal tap for now as it's real-time result.
Let me know do you have any further concern?
Sheng
Antworten
