GPU Compute Software
Ask questions about Intel® Graphics Compute software technologies, such as OpenCL* GPU driver and oneAPI Level Zero
355 Discussions
Silent exit with execution policy on NEO.
Dmitry_Savin
Nouveau contributeur I
16 016 Visites
I am trying to use PSTL with std::vector.
A simple program fails to compile for FPGA Emulation Device and OpenCL CPU device with cl::sycl::compile_program_error, which provides some information, at least.
But on the OpenCL HD Graphics it silently exits.
Why does it happen and how to debug such fails?
The command to compile is
dpcpp -tbb -lpthread main.C -O0 -g -std=c++20
The output, gdb output and the source are attached to this post.
On the SYCL host device a program that skips NEO gives
terminate called after throwing an instance of 'cl::sycl::runtime_error'
  what():  Sub-group feature is not supported on HOST device. -33 (CL_INVALID_DEVICE)
So it compiles, at least.
Suggestions how to make it work on any of devices are appreciated.
PS It removes main.cpp attachment because "The attachment's main.cpp content type (text/x-c++src) does not match its file extension", so changed it to main.C.
0 Compliments
Dmitry_Savin
15 837 Visites
The non-free drivers are required for an integrated GPU, too.
After the reinstallation the programs work on the Intel(R) OpenCL HD Graphics
 platform.
I think that this topic should be renamed to "Silent exit on NEO" because the issue was not with the PSTL, and can be closed,
unless someone can explain why there is no Level-Zero platform for the GPU, while it is present in a system with the same driver installation and a similar GPU? This one is reported as Intel Corporation UHD Graphics 630 (Mobile) in i7-8750H CPU, the other - Intel UHD Graphics 620 (rev 07) in i5-8250U CPU. Both systems are up-to-date Ubuntu 20.04 LTS.
Voir la solution dans l'envoi d'origine
0 Compliments
10 Réponses
Dmitry_Savin
15 947 Visites
A simplified version that calls fill like the example fails the same way.
0 Compliments
Dmitry_Savin
15 941 Visites
An asynchronous exception handler does not give any additional information.
0 Compliments
GouthamK_Intel
Modérateur
15 862 Visites
Hi Dmitry,
Thanks for providing the reproducer and steps to reproduce.
>>"A simplified version that calls fill like the example fails the same way."
We tried to compile to run the code on our end, and we didn't face any issues, the code was executed successfully.
Please refer to the below screenshot.
Could you share more details about your system environment?
OSVersion:
DPCPP Compiler Version:
GPU Device:
Driver Version:
Thanks & Regards
Goutham
0 Compliments
Dmitry_Savin
15 847 Visites
OSVersion: Ubuntu 20.04.2 LTS
DPCPP Compiler Version: 2021.1.2 (2020.10.0.1214)
GPU Device: Intel Corporation UHD Graphics 630 (Mobile)
Driver Version: 5.4.0-67-generic
UPD Below the tail of the strace output is attached.
UPD The guide says that additional GPU drivers are to be installed if either it is te first installation of the OneAPI, ore the Intel GPU is discrete.
Anyway, I noticed the Level Zero device in your output, and I am updating by the guide.
Please notify the repository maintainers that it is impossible to update with i386 packages installed due to unsatisfied dependencies.
0 Compliments
Dmitry_Savin
15 838 Visites
 platform.
0 Compliments
GouthamK_Intel
Modérateur
15 810 Visites
Hi Dmitry,
>>"why there is no Level-Zero platform for the GPU, while it is present in a system with the same driver installation and a similar GPU?"
Could you please share the complete output of the below two commands for both the systems you are referring to?
  1. clinfo
  2. sycl-ls --verbose
Goutham
0 Compliments
Dmitry_Savin
15 802 Visites
UPD found that intel-level-zero-gpu wasn't installed on one of the systems, installing fixed the issue.
The attached files contain the original output.
Hi Goutham,
Find them attached below.
This post was edited to include the output from the other device.
Dmitry
0 Compliments
GouthamK_Intel
Modérateur
15 778 Visites
Hi Dmitry,
>>"found that intel-level-zero-gpu wasn't installed on one of the systems, installing fixed the issue."
Glad to know that your issue is resolved, could you please let us know if we can close this thread from our end?
Goutham
0 Compliments
Dmitry_Savin
15 768 Visites
Hi Goutham,
You can close this thread.
Dmitry
0 Compliments
GouthamK_Intel
Modérateur
15 757 Visites
Hi Dmitry,
Thanks for the confirmation!
As this issue has been resolved, we will no longer respond to this thread.
If you require any additional assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only.
Have a Good day.
Thanks & Regards
Goutham
0 Compliments
Répondre
