Everytime I wake up my sleeping monitor, two popups will show up:
This is quite annoying, can we get rid of them?
Hello fireattack.
We understand that you receive a pop-up message every time you open to wake up the system.
To have more insight into your issue, please provide us with the following information:
- Does the issue persist on different drivers?
- Please, try installing the latest Intel® Arc™ 31.0.101.4091, and confirm if the issue is still present.
- Create a report using the Intel
System Support Utility (Intel SSU) - Download the Intel SSU
- Open the application and click on "Scan" to see the system and device information. By default, Intel
SSU will take you to the "Summary View." - Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click on "Next"; then "Save."
Jean O.
Hi, this is the first time I install ArcControl, so no idea if it's like this before.
My driver is indeed 31.0.101.4091.
The SSU scan result is attached.
Please note that it's waking about the monitor only. The computer never went sleep.
Hello fireattack,
We appreciate the information provided.
Let us look into this and we will get back to you at our earliest convenience.
Jean O.
Hello fireattack
Thanks to your reports, we have replicated this issue, and it has been reported to the driver developer team. We are working on a solution for this issue, and it will be implemented in upcoming Arc Control releases. Unfortunately, we are unable to commit to any specific time. Here is a list of known issues with the Intel Arc Control software.
Since this will take further effort from us, and to avoid duplicate efforts, we are considering closing this thread, but we would like to confirm if you agree with closing this thread.
Jean O.
Hello fireattack,
We hope you are doing fine.
Best regards.
Jean O.
![](/skins/images/318B71AC6E18CAB8E2CA944B2397E849/responsive_peak/images/icon_anonymous_message.png)
