718 Discussions
Fortnite keeps crashing on latest intel driver. Anyone know which driver is stable?
Phoenics
Cpu: i5 1135g7
Ram: 16gb ddr4 2400mhz (single channel)
igpu: intel iris xe g7
Storage: 512 GB Nvme
OS: Windows 11 home
Driver: 32.0.101.101.6253
After updating my drivers (which is normally something you should do to (!) get better performance or fix issues), fortnite keeps crashing mid match, or even just while in the lobby. I have already checked if any other programs, command lines, tweaks or ingame settings cause this, and no, everything is ok. Its the driver that causes this issue, but i dont know which driver is stable.
Does anyone know a iris xe driver version that doesnt keep crashing my game? (other games work just fine)
- >Phoenics
ACarmona_Intel
Hello Phoenics,
Since the issue only happens after you have updated your graphics driver to Driver: 32.0.101.101.6253, kindly perform a rollback so it will be your previous driver that will be installed again on your system.
Please follow the steps on the link below on how to roll back your graphics driver:
If you have any questions, please let me know, and also, please inform me of the result once you have already performed the rollback of drivers.
Carmona A.
Phoenics
Yes, rolling back the drivers worked, but it introduced screentearing. (currently on 32.0.101.5972)
Shouldnt this issue be adressed instead of telling people to try out several drivers, spending a lot of time restarting, updating, reinstalling etc. to find out which version works? I think Intel should bring out drivers that are stable, that people can actually use.
DhannielM_Intel
Hello Phoenics,
I hope you had a chance to review the information we provided in the previous reply. At your earliest convenience, please provide your response so we can further investigate and resolve the issue.
Dhanniel M.
ACarmona_Intel
Hello Phoenics,
Thank you for the response.
Please update your graphics driver to our latest one, which is 32.0.101.6449/32.0.101.101.6256, then try Fortnite.
And if you still encounter any issue, please share with me your SSU, as it contains your system's specifications and configurations in order for me to deeply investigate our issue.
To generate the SSU report, please refer to the article: How to Get the Intel® System Support Utility Logs on Windows. Please send me the generated SSU.txt file.
And also, when the Fortnite crashes, does it display any error messages? If yes, is it possible that you can share it with me?
Carmona A.
ACarmona_Intel
Hello Phoenics,
This is only a quick follow-up; I just wanted to check in with you, as I haven't received any feedback from you.
Thank you.
Carmona A.
ACarmona_Intel
Hello Phoenics,
I'm still looking forward to your update.
Carmona A.
NormanS_Intel
Hello Phoenics,
I appreciate your patience and apologize for the delay in our response as we have been conducting a detailed investigation. Based on our findings and after releasing several driver versions, we recommend updating your graphics driver to the latest version, 32.0.101.6651. We believe this will address the issues you've been experiencing. Please let us know the results once you've made the update.
Norman S.
NormanS_Intel
Hello Phoenics,
I hope you had the chance to review the information I posted. Please let me know at your earliest convenience so that we can determine the best course of action to efficiently resolve this matter.
Norman S.
NormanS_Intel
Hello Phoenics,
Norman S.
