661 Discussions
firmware files might be missing for the i915 kernel module
Processor
Can any body help me solve this (running on kali linux)
update-initramfs: Generating /boot/initrd.img-6.5.0-kali2-amd64
W: Possible missing firmware /lib/firmware/i915/mtl_huc_gsc.bin for module i915
W: Possible missing firmware /lib/firmware/i915/mtl_guc_70.bin for module i915
IsaacQ_Intel
Hello @Processor
1.      What is the issue exactly, does it only give you that error?
2.      Are you running the latest stable kernel version?
We must let you know that we only have drivers for ARC, 11th, 12th, 13th - Intel® Arc™ Graphics Driver - Ubuntu*.
Additionally, in order to facilitate more extensive research, we will need access to the SSU report.
SSU: Please download and scan your system using our tool, Intel® System Support Utility so we can help check your system info first. Once finished downloading, open the tool, click on scan 'Everything', click next, then save the system information to a .txt file. Please provide the .txt file.
This document will be necessary to check your entire system, in order to find possible errors or incompatibilities.
Isaac Q.
Sadimahmud
i am getting the same message in my laptop.My cpu is Intel(R) Core(TM) i3 CPU M 380 @ 2.53GHz.Now i am useing kalilinux.My gpu often crsh after i placed mtl_huc_gsc.bin & mtl_guc_70.bin in i915 directory.then i removed them from the directory.Now what should i do.should i just ignore this missing message...???
IsaacQ_Intel
Hello Processor
We hope you are doing fine.
Please answer our questions,  What is the issue exactly, does it only give you that error? Are you running the latest stable kernel version? And provide us with the SSU.
Also as we said before, we only have drivers for ARC, 11th, 12th, 13th - Intel® Arc™ Graphics Driver - Ubuntu*.
Let us know if you still need assistance. Otherwise, we will close the thread.
Isaac Q.
IsaacQ_Intel
Hello Processor
Best regards.
Isaac Q.
AlHill
@Sadimahmud
You should update your hardware to something 11th gen or later.  You are running a 1st gen cpu.  That is 14 years old and no longer supported.
[If you find any Intel driver you might need, download and save it now.]
