656 Discusiones
intel i7-14700kf low clock speeds
Manteske
Principiante
2.051 Vistas
  • Hi  i  noticed recently that my pc fps is not stable as it should be especially when there much going on which my processor should have no problem dealing with so i decided to run some stress tests i ran cinebench multicore test then OCCT and noticed as soon as i start the test my voltages and  core clock speeds drops immediately from 1,3V to 0,9V and from 4.3ghz to 3,6ghz and  im not thermal throttling i get 55c max while running the  test and  i've  got a good 360mm lian li cooler.
0 kudos
5 Respuestas
Mike_Intel
Moderador
1.986 Vistas
Hello Manteske,
  1. Can you provide the title of the games that you are playing?
  2. This processor does not have onboard Graphics. Can you tell me the brand and model of the Graphics controller that you are using?
  3. When did you start having this issue?
  4. What was the last change made in the system before you start to have this issue?
  5. Please help generate the SSU logs of your system for me to check the hardware and installed drivers. Please refer to the link below on how to generate the logs:
Michael L.
angela852black
Principiante
1.757 Vistas
Your CPU is likely power throttling, not thermal throttling. Check your BIOS power limits (PL1/PL2 or PPT) and raise them. Also, ensure you're using a High Performance power plan in Windows.
Best Regard,
Angela
Mike_Intel
Moderador
1.629 Vistas
Hello Manteske,
@angela852black
Thanks for your input.
Michael L.
AbdulJami
Principiante
1.454 Vistas
Your CPU is likely throttling voltage and clock due to power limits, not temperature. Check BIOS power settings and update firmware.
Mike_Intel
Moderador
1.156 Vistas
Hello Manteske,
I am sending another follow up on the information that I requested.
Michael L.
Responder
