I got the same rendering problem on my Laptop as described in the following link:
Re: Rendering problem in Genshin Impact on Iris Xe 80EU - Intel Communities
I did everything described in this link and installing a previous driver worked.
Sadly only for two days, because theres an automatic update which updates the driver like every two days.
I already tried to stop the driver update in my windows settings, which did not work and I cant find an option for stopping the automatic updates in the Intel grafic controlroom.
So my question is how can I stop the automatic driver updates for intel iris xe?
these are the specifications of my laptop:
core: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz 2.42 GHz
Windows 10 Home Version: 21H2
Hello J0na,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Iris® Xe Graphics.
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
- Download the Intel® SSU and save the application on your computer: https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
- Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change it to "Detailed View".
- To save your scan, click Next and click Save.
2. Provide the Report for Intel® Graphics Drivers:
3. Can you take a short video of the issue?
4. Do you see the same issue with the driver from the laptop manufacturer?
Deivid A.
I made both of those scans.
The Video sadly lags a bit because I was running the game and the recording program at the same time.
The manufacturer of my laptop is medion. As far as I know, they dont provide own drivers.
Hello J0na,
Thank you for the information provided
Deivid A.
Hello J0na,
Thanks for your time. I would like to let you know that I tried to replicate this issue but I did not get the same problem. You can watch the video attached,
In order to continue, I would like to know if you have any specific settings in-game and if so, please take pictures of these settings.
Bear in mind that depending on the quality chosen (High, Low, lowest) the performance varies but this will be dependent on the hardware being used too like RAM, hard drive, etc.
Deivid A.
Hello J0na,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
Hello J0na,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
Hello J0na,
As the last recommendation, try to check this behavior with the game developer for instruction and advice.
Also, you can encourage other users to report this issue so we can get a better view of the impact and we may continue with the investigation if needed.
Deivid A.
![](/skins/images/DCC883141309A464C31AD18F1D8B9C6A/responsive_peak/images/icon_anonymous_message.png)
