Intel® UHD Graphics 620. Не могу установить разрешение 1920х1080 на мониторе Samsung SyncMaster P2770HD. С другим компьютером - работает. Intel® UHD Graphics 620. При выборе разрешения 1920х1080 картинка становится больше рабочего стола и графика ужасная. Подходит только разрешение 1600х1200. Но картинка слишком растянутая и мыльная. Драйвер удаляла и переустанавливала на свежий - версии 26.20.100.7584.
Hello TKipr,
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool embedded on this Intel Community.
To better assist you with your request, I will need to check some information about your computer. Please follow these steps and attach the reports generated directly to the thread:
Please connect the monitor to the laptop when generating the reports.
1. Intel® System Support Utility (Intel® SSU)
- Intel® SSU Download link
- Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
2. DXDIAG
- Go to Start > Run or Windows Key + R.
- On the Run prompt, type "dxdiag" then click OK.
- On the DirectX Diagnostic Tool window, click on Save All Information.
- Browse to a folder, type in a filename then click Save.
Questions:
- Does the other computer that can get the resolution have Intel® UHD Graphics 620 as well? please provide the model.
- Are you doing straight connections? (like HDMI to HDMI) or are you using an adapter/dongle?
- Have you tested with the latest OEM drivers instead of the Intel® generic drivers 26.20.100.7584?
- Have you tested a different monitor?
Adrian M.
A Contingent Worker at Intel
Hello TKipr,
Let me know if you need more assistance.
Adrian M.
Hello TKipr,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Adrian M.
