Добрый день, проблема которая не исчезает, пробовал пару способоов и методов, переустанавливал, использовал ваши утилиты, для автоматического поиска драйверов и установки.
Ничего не помогает, я не могу открыть HD Graphics Settings
У меня просто ее нет.
Открываю папки intel. а там по вообще нету никакого exe. файла
Очень странно
Надеюсь вы мне поможете
Hello PPras2,
Thank you for posting on the Intel ® communities.
To better assist you with your request, I will need to check some information about your computer. Please follow these steps:
1. In the keyboard, press WinLogo key + R.
2. In the Run box please type dxdiag and hit Enter.
3. Click on Save All Information (save it in your desktop).
4. Attach the report to this thread.
David V
Hello PPras2,
Thank you for your response.
According to the report you have attached, the Windows* version you have installed in the system is not the latest, neither is the graphics driver for the Intel ® HD Graphics. Keep in mind that your system has hybrid graphics so it is recommended to contact the manufacturer of your system for assistance with the update of the graphics drivers which in this case would be MSI* according to the model provided.
Something I can recommend you to do is to try with the following combination of keys: "CTRL + ALT + F12", this combination normally opens the graphics properties. If this does not work then you can try downloading the Intel ® HD Graphics control panel from the link below:
https://www.microsoft.com/en-us/p/intel-graphics-control-panel/9ndlclmmtmrc?activetab=pivot:overviewtab
David V
Hello PPras2,
Were you able to check my post?
Please follow the instructions to see if the issue is addressed.
David V
Topic Options
