22648 Discussions
4:3 game stretches, no maintain aspect ratio in intel hd graphics control panel
KMann6
Débutant
5 960 Visites
so yeah, i'm trying to play a game that has 4:3 resolution, but instead of black border appearing on both sides the game stretches to fill the entire screen. i went into my intel hd graphics control panel to turn on maintain aspect ratio, but i didn't any option for it. all i have is 'center image' and 'maintain display scaling'. i need some help
0 Compliments
10 Réponses
JEFFREY_F_Intel
Employé
2 936 Visites
try changing the resolution in the control panel to a non-native resolution first.. then the maintain aspect ratio should be available
0 Compliments
KMann6
Débutant
2 936 Visites
i've tried that already. all that shows up is 'center image'
0 Compliments
Jose_H_Intel1
Employé
2 936 Visites
I believe the best way to go is leaving Intel® HD Graphics settings by default and only change the resolution within the game settings.
0 Compliments
KMann6
Débutant
2 936 Visites
there is no option for that in the game's settings, otherwise i would have already tried it
0 Compliments
Jose_H_Intel1
Employé
2 936 Visites
So, the options Center Image or Maintain Display Scaling do not help?
What is the game title and Intel® HD Graphics / Intel® processor model?
http://www.intel.com/support/graphics/sb/CS-009482.htm Graphics Drivers — How to Identify Your Intel® Graphics Controller
0 Compliments
KMann6
Débutant
2 936 Visites
correct.
it is a japanese game, called koihime musou. it is interl(r) hd graphics
0 Compliments
Jose_H_Intel1
Employé
2 936 Visites
It may help updating your system BIOS.
0 Compliments
KMann6
Débutant
2 936 Visites
0 Compliments
ROBERT_U_Intel
Employé
2 936 Visites
@ kman082008, Could you please provide the following information regarding this issue?
1, What version of Intel HD Graphics driver are you seeing this issue with?
2. What Intel processor is in your system
3. What is the model of the system you are using?
4. What operating system are you using?
5. What is the model of the display you are using?
6. How is the display connect to the system (HDMI, VGA, DVI, DP)?
Robert
0 Compliments
Jose_H_Intel1
Employé
2 936 Visites
BIOS updates are obtained through the http://www.intel.com/support/oems.htm system manufacturer and may include Video BIOS updates.
http://www.intel.com/support/graphics/sb/CS-029985.htm Graphics Drivers — Video BIOS FAQ
I recommend you checking with them as a failed or unsuccessful BIOS update may damage the system without possibility of recovery.
Répondre
