22643 Discussions
4:3 game stretches, no maintain aspect ratio in intel hd graphics control panel
KMann6
so yeah, i'm trying to play a game that has 4:3 resolution, but instead of black border appearing on both sides the game stretches to fill the entire screen. i went into my intel hd graphics control panel to turn on maintain aspect ratio, but i didn't any option for it. all i have is 'center image' and 'maintain display scaling'. i need some help
JEFFREY_F_Intel
try changing the resolution in the control panel to a non-native resolution first.. then the maintain aspect ratio should be available
KMann6
i've tried that already. all that shows up is 'center image'
Jose_H_Intel1
I believe the best way to go is leaving Intel® HD Graphics settings by default and only change the resolution within the game settings.
KMann6
there is no option for that in the game's settings, otherwise i would have already tried it
Jose_H_Intel1
So, the options Center Image or Maintain Display Scaling do not help?
What is the game title and Intel® HD Graphics / Intel® processor model?
http://www.intel.com/support/graphics/sb/CS-009482.htm Graphics Drivers — How to Identify Your Intel® Graphics Controller
KMann6
correct.
it is a japanese game, called koihime musou. it is interl(r) hd graphics
Jose_H_Intel1
It may help updating your system BIOS.
KMann6
ROBERT_U_Intel
@ kman082008, Could you please provide the following information regarding this issue?
1, What version of Intel HD Graphics driver are you seeing this issue with?
2. What Intel processor is in your system
3. What is the model of the system you are using?
4. What operating system are you using?
5. What is the model of the display you are using?
6. How is the display connect to the system (HDMI, VGA, DVI, DP)?
Robert
Jose_H_Intel1
BIOS updates are obtained through the http://www.intel.com/support/oems.htm system manufacturer and may include Video BIOS updates.
http://www.intel.com/support/graphics/sb/CS-029985.htm Graphics Drivers — Video BIOS FAQ
I recommend you checking with them as a failed or unsuccessful BIOS update may damage the system without possibility of recovery.
