- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello ravenhol,
Thank you for posting on the Intel®️ communities. I see that you are having graphic corruption issues with your Intel® Arc™ A770 Graphics, I understand how frustrating this can be, I will be happy to help you.
To have a better understanding of the situation, please answer the following questions:
- When did the issue start?
- Did you make hardware and software changes? If so, which ones?
- What ports are you using to connect the monitor?
- Are you using a display adapter or docking station? If so, what is the make and model?
- What is the power supply make and model?
- What is the monitor's make and model?
- Download, run, save and attach the report for the following tool Intel® System Support Utility for Windows (SSU) to check your hardware and system information, you can find the steps on the link How to get the Intel® System Support Utility Logs on Windows.
Andres P.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi. I try to tell you what i know. At last time: i turn on twitch (from opera browser) for world of tanks dropps. And in the same time i play games like world of tanks or fallout 76. And i randomly check the drop progress. And at this time happened when i press the windows key for put down the game window for switch to opera. (+ on world of tanks can happen when i turn off the v sync. ) i dont change anything. Im use hdmi cabel. My monitor is asus vg245h. psu seasonic b12 bc-750
i dont use any display adapter or docking station.
im updated my vga driver for the lastest version after my first post.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello ravenhol,
Thank you for your response, all the information provided has been really helpful.
Please follow the steps below and let me know the results:
- Test the graphics card using a different port, cable, and monitor or TV.
- Clean install graphics driver to version 31.0.101.4578 Display Driver Uninstaller (DDU). For guidance, How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver.
- If the issue persists, repeat the previous steps but this time by downloading 31.0.101.4644.
- Update the BIOS to the latest version, you can contact Gigabyte for guidance.
Andres P.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello ravenhol,
Were you able to clean install the graphics driver to version 31.0.101.4578 and version 31.0.101.4644?
Andres P.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello ravenhol,
Andres P.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
