22692 토론
Aero crashing on Win7 with an i7-6700HQ
TBLz
초급자
15,376 조회수
Hi !
I bought a brand new MSI PE70 6QE with Win10, but for some reasons I decided to install Windows 7 instead.
The problem is that after installing all the last drivers, everything is running well EXCEPT that the computer is unable to run Aero more than 30 minutes. It makes quite mad because my older computer (with an i5 and only 6Go of DDR3) had no problems running it, and now that I bought a good computer (i7-6700HQ and 24Go of DDR4) it doesn't survive to Aero.
It looks like the integrated graphics are not powerfull enought. Can someone help me with my problem? I'd really like to run Aero smoothly on a computer with that configuration !
Thanks a lot, and sorry for my english !
MSI PE70 6QE
Intel Core i7-6700HQ
Nvidia GeForce GTX 960M (2Go)
SSD 500Go + HDD 1To
24Go DDR4
Windows 7 Pro 64bits
0 포인트
66 응답
TBLz
초급자
2,757 조회수
Hi guys ! I'm currently on holidays so I don't have my computer with me. I'll update the bios as soon as I'll be back at home, next week.
Thanks for your help,
Thomas
0 포인트
직원
2,757 조회수
Great, thank you for letting us know.
Esteban C
0 포인트
TBLz
초급자
2,757 조회수
Hi all !
I'm back and I've finally updated the BIOS. It hasn't solved the problem. The computeur is still lagging after a few minutes, and instantly if Aero settings are "normal" and not "lowered".
I actually disable some of Aero settings so it works a little bit longer, but at the slightest solicitation, it starts lagging again and Aero is turned off.
Thanks for your help !
0 포인트
CCris2
새로운 기여자 II
2,757 조회수
Hi WTPThom and welcome back
So in the meantime there is new driver: https://downloadcenter.intel.com/download/25957/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345 Download Intel® Beta Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.40]
Test it and see how its working.
0 포인트
직원
2,757 조회수
Thank you Ronin for your input on this, WTPThom, please keep us updated on this testing with the suggested driver.
Esteban C
0 포인트
TBLz
초급자
2,757 조회수
Hi guys,
I updated the driver on Friday night, but the problem is unfortunately still here...
0 포인트
CCris2
새로운 기여자 II
2,757 조회수
There is new driver for nvidia :http://www.geforce.com/drivers/results/102995 Drivers | GeForce
I don't know if it will solve your problem but you can try it.
0 포인트
직원
2,757 조회수
Let me further investigate into this peers, I will keep you updated.
Esteban C
0 포인트
TBLz
초급자
2,757 조회수
Hi guys,
Just a quick update to tell you that even after updating the Nvidia Driver, the problem is still here.
Thank you for your help and researches by the way !
0 포인트
직원
2,757 조회수
Thank you for your input on this WTPThom, I will keep you updated on my research.
Esteban C
0 포인트
CCris2
새로운 기여자 II
2,757 조회수
Hi WTPThom,
Well There is a new firmware with a simple description: "Fix workaround fan random stop issue" ... So if fan is stopping then the system is overheating and that is a big probability why your system is going slower.
Check is is right for your system and make that firmware update also.
https://www.msi.com/Laptop/support/PE70-6QE.html# down-firmware Support For PE70 6QE | MSI Global | Laptops - The best gaming laptop provider
It seems that MSI did some problems on their own ...
0 포인트
TBLz
초급자
2,757 조회수
Firmware updated.
The problem is still here. The fan was already activating itself, and if not, I have a button to activate it manually. And even with the fan giving all it's got, the computer isn't going faster..
I'm actually lowering Aero settings so it can run under "basic" conditions, but as soon as I'm using Photoshop or Sketchup, goodbye Aero..
But I find it a little bit strange because in the Nvidia Configuration Panel, I've set the global parameter to "Nvidia Graphics", plus those programs too !
0 포인트
CCris2
새로운 기여자 II
2,757 조회수
I think there is something wrong with driver compatibility. I tested an older gts 8800 on windows 8.1 and windows 10 with a decrypting program. With the same driver on windows 10 I could use only about 16 threads without crashing the driver, and on windows 8.1 I could use 180 threads. The biggest surprise was that on both situations the decrypt time was the same ...
I can reach to a conclusion. I think that nvidia is using the same drivers for all windows versions, and it creates problems. Because if they optimize the drivers for windows 10 on which it seems it runs faster, on windows 7 will run slower. If it runs slower then it will create some problems, like the one you have now with aero ...
In Nvidia Config Panel try to set Internet Explorer to performance. Windows uses Internet Explorer for desktop ...
0 포인트
CCris2
새로운 기여자 II
2,757 조회수
Nvidia released new driver 3 days ago: http://www.geforce.com/drivers/results/103911 Drivers | GeForce , but before you install it I advise you to uninstall the old one using this program: http://www.guru3d.com/files-details/display-driver-uninstaller-download.html Display Driver Uninstaller Download version 16.0.0.2
0 포인트
TBLz
초급자
2,757 조회수
Thanks for this. Uptade done.
I've tried to set the Aero settings at their maximum, and it started lagging instantly, BUT, I tried one thing that I haven't tried before.. I unplugged my second screen (the Samsung), and it stopped lagging ! I opened 2 Sketchup windows with complex 3D models, it wasn't lagging at all, I replugged the second screen.. Boom, the lag was back !
Unplugged, no lag, plugged, big lag and Aero is turning off !
Do you have an idea of why it's doing this? I guess we're making a good progress on finding the center of the problem !
Edit : I've also put Internet Explorer setting to "Nvidia performance graphics"
0 포인트
CCris2
새로운 기여자 II
2,757 조회수
I think you should report this to MSI also, it looks like is a power problem. When it uses 2 displays it uses more power. I used both dvi and hdmi outputs on my i7 6700k and I don't have that slow down problem. But on desktop I have more available power to the cpu and graphics.
Send a message with the problem you have with the monitor model you connected, so that they can do some testing, because they can modify some settings in bios, if it is a power problem, to give more power to the gpu or igpu.
0 포인트
TBLz
초급자
2,757 조회수
Thanks Ronin,
I've sent a message to MSI Support. I'll keep you updated of what they say !
0 포인트
직원
2,757 조회수
Thank you for your contribution on this Ronin, really helpful.
WTPThom, please keep us posted on the answer provided by the manufacturer of your device.
The tests performed on my end were ok, tested with the nearest configuration available Intel® NUC Kit NUC6i5SYK
Esteban C
0 포인트
TBLz
초급자
2,757 조회수
Hi all !
I contacted MSI Online support, they asked me to update VBIOS, EC Firmware etc.. I retried everything without resolving the problem. They have tried to replicate my situation with the same computer, but they don't have my problem. So they now think that it's a hardware problem, maybe coming from the HDMI port. They told me to contact the local Support shop. I sent them an email. We'll see !
0 포인트
CCris2
새로운 기여자 II
2,749 조회수
This was faster then writing here and wasting another week or 2
0 포인트
직원
2,749 조회수
Thank you for letting us know about that WTPThom, hope this gets fixed with the new motherboard.
Please keep us posted on this matter to see how it goes.
Any further inquiries or questions, feel free to let us know.
Esteban C
0 포인트
응답
