22672 Discussões
Arc 770 not allowing multi display
Robray
Principiante
17.994 Visualizações
Gig gaming x ax with i5 13600k. Arc770. If I try and boot with 3 displays
1 on igpu
2 on 770
It fails to post if I hot plug the hdmi 770 display it sets up all ok until pc is rebooted.
All 770 ports tested ok the only event error reads as a pnp api miss match from last os
Etiquetas (1)
29 Respostas
Jean_Intel
Funcionário
13.093 Visualizações
Hello Robray,
Thank you for posting on the Intel️® communities. We understand that you are experiencing issues when plugging three monitors into your system.
  • Did the system use to work as expected before?
  • Are you using any type of adapter? We always recommend using straight connections.
  • Have you tried plugging all the monitors into the Arc graphics?
  • What Operating System and version are you running?
Jean O.
Robray
Principiante
13.082 Visualizações
It was problem from new. I upgraded to i5 13600k z790 motherboard ddr5 men new NVMe 2gig. With existing R7800 and gpu.
Reloaded win11 pro okay had dell 12” LCD hdmi on igpu,
gpu 27” ASU’s 4k DisplayPort and LG oled tv hdmi.
Replaced with arc770 whenever DisplayPort and hdmi port used system fails to post I managed to get a Samsung tv on hdmi port to work only by having both Samsung tv and ASUS monitor set to 1920x1280 and 30hz by hot plugging tv but as soon as pc rebooted it failed to load all screens and just an inactive display always
Jean_Intel
Funcionário
13.054 Visualizações
Hello Robray,
This time we would like to recommend you perform a clean installation of the driver installing our latest 31.0.101.4091. Sometimes, corrupted files from the previous installations might be causing a malfunction that causes driver cause driver updates to not work as expected.
If the issue is still present after the clean installation, please provide us with the following system reports:
  • Intel®️ System Support Utility (Intel®️ SSU)
    • Download the Intel SSU
    • Open the application and click on "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click on "Next"; then "Save."
  • Create a report using the Intel® Graphics Command Center:
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
Robray
Principiante
13.007 Visualizações
Still have problems I am preparing to reinstall a fresh windows 11 pro installation. I do not have any extra displayport monitors to test but am getting a do to hdmi cables to to test just from do ports
boazvdw
Principiante
12.995 Visualizações
HDMI on ARC cards is cursed on the current drivers. I've opened an issue already but from what I've heard there are a ton of people experiencing issues like losing video output over HDMI, and it's been there from the start. For me waiting a little bit seems to fix the video output eventually or try replugging your HDMI cable. If that doesn't work I'm afraid you are stuck with using displayports until Intel finally solves the hdmi issues unfortunetly
Jean_Intel
Funcionário
12.971 Visualizações
Hello Robray,
We will wait a few days for you to try the fresh Windows installation and different HDMI cables.
If the issue is still present after completing these steps, provide us with the system reports we requested before, Intel®️ SSU, and  Intel® Graphics Command Center report.
Jean O.
Robray
Principiante
12.955 Visualizações
Today I received 2 dp to hdmi adapters fitting them to arc a770 ports did test boot all okay. So then connected the hdmi cable from lg oled 4k tv. With the the 4k monitor display still connected via dp port and lcd screen connected to igpu hdmi on motherboard . On initial post all seems now to work so fault seems to be a handshaking driver problem with hdmi port on arc a770. I will try further tests.
Jean_Intel
Funcionário
12.950 Visualizações
Hello Robray,
We appreciate your effort and proactively trying some troubleshooting to solve this issue.
Once you complete the test you mentioned, please share with us the outcome, and as we previously mentioned, share the system Intel SSU and IGCC reports.
Jean O.
Robray
Principiante
12.925 Visualizações
I appear to be getting a result but is it worth messing up windows. I now have a working display setup.
Bios primary gpu pci-bus , input set to on.
Dell 1707fp hdmi to mother board
LG oled tv connected to hdmi on arc a770
ASUS 4k 28” monitor using DP/HDMI adapter connected to DP port on arc a770
Samsung HD 32” tv using DP/HDMI adapter connected to DP port on arc a770.
This works all the time after reboots tv’s turned on and off.
As soon as a display port connection is used with just normal cable to monitor it causes problems windows fails to load properly screens go erratic often the igpu monitor image shows from part of 4k screens and becomes main screen and displayport screen shows as inactive.
If reduced to just display port screen on gpu and lcd on igpu it works but if displayport and hdmi mixed on arc a770 erratic screens happen and when windows loads 3 or 4 resets happen before settles on one hdmi display and displayport display shows as inactive although it sees it but unable to extend to it.
Robray
Principiante
12.917 Visualizações
It appears to me the Intel arc drivers label the HDMI connection as displayport and when windows loads it sees an HDMI connection and they conflict windows seems to favour hdmi but not always the outcome can be varied but the result is one of them will show as inactive and cannot be extended to in settings
Jean_Intel
Funcionário
12.888 Visualizações
Hello Robray,
Thank you for the information you have shared.
We would like to follow investigate this issue, and to continue with the support we would like to request once more, the system reports:
  • Intel System Support Utility (Intel SSU)
  • Intel® Graphics Command Center:
Jean O.
Robray
Principiante
12.844 Visualizações
please find reports of tests tested first with 4 hdmi screens all ok then added displayport screen it failed to display unable to extend to it although it was identified , then reverted back to 4 hdmi screens all ok again.
the displayport monitor was connected to same gpu port as asus hdmi but without adapter cable
Robray
Principiante
12.810 Visualizações
I started new test
iGPU  1 HDMI display
ArcA770  1 HDMI with adapter cable in Display port and 1 display in HDMI port
Robray
Principiante
Test 2
iGPU  1 HDMI display
ArcA770  1 HDMI display in hdmi port
1 Display in same Display port without Adapter
Display port display not showing anything but showing as inactive unable to extend to it
Robray
Principiante
12.806 Visualizações
Test 3
iGPU 1 HDMI display
ArcA770  1 HDMI on hdmi port and 1 Display on another DP port
still no display and unable to extend to it just stays inactive
Robray
Principiante
12.803 Visualizações
test 4
iGPU 1 HDMI display
ArcA770 1 Display on DP port only
Both displays work ok
Robray
Principiante
Test 5
iGPU 1 HDMI display
ArcA770 GPU 1 Display on Displayport   HDMI display added to HDMI port
Displayport display not active HDMI displays ok
Robray
Principiante
12.802 Visualizações
Test 6
iGPU 1 HDMI display
ArcA770  1 HDMI display with displayport adapter 1 Display on HDMI port
all worked ok
Jean_Intel
Funcionário
12.756 Visualizações
Hello Robray,
We appreciate the information you shared about the different tests you have performed.
Checking the reports you have shared, we noticed the following:
The integrated graphics driver is reported to be 31.0.101.4140. The driver version is not reported on the Motherboard website nor in our Download center. We recommend a clean installation of the latest driver from Gigabyte, 31.0.101.3302. We always recommend using the drivers provided by the system manufacturer (OEM)
Your Operating System build is 22623; this is an Insider version. Remember that this type of build is intended for testing, and for the most stable experience, you should always install the latest production build. Could you install the latest production version available at the moment, 22621?
You mentioned that the issue is caused by multiple environments. Could you inform us if this issue is always present on the same monitor, or is it not related to the monitor model?
Also, there is no IGCC report. Note that this will show information about the monitors you are using,.Could you share with us the Intel® Graphics Command Center?
Jean O.
Robray
Principiante
12.751 Visualizações
When I loaded IGCC it said it could not generate a report but gave no reason
Responder
