23066 Discussions
ArmA 3: DXGI_ERROR_DEVICE_REMOVED seems driver related
ICust27
Ever since ArmA 3 was released as an alpha back in March, it plagued me (and quite a few others) with these apparently random DirectX 11 crashes (either freezing or CTD):
"D3D Error - DXGI_ERROR_DEVICE_REMOVED"
"Display Driver Stopped Responding and has recovered."
A few days ago I, acting on a hunch, installed an old driver (15.28.7.64.2867) from October(?) 2012 and was able to play the game without any crashes in area's/maps that were unplayable before.
Working my way up (I have some, but not all drivers released) I found that the drivers up to 9.17.10.2932 (December 2012) perform flawlessly, while 9.18.10.3071 (March 2013) and later tend to suffer from this issue.
So while installing the latest drivers is recommended as a starting point for every glitch, in this case it is not going to get you anywhere: it seems that every iteration has inherited a flaw that was introduced somewhere during that period (December 2012 - March 2013).
I hope this in some way helps you to tackle this issue, and allows me to have my graphics driver up to date in the near future...
These 'tests' were performed, ceteris paribus, on this machine:
Intel i7-3770K@3500|3900 (HD 4000@1150)
MSi Z77A-GD65 (UEFI: 10.11ß)
32GB Corsair Vengeance@1600
Windows 8.1_x64
All drivers were up to date.
JPala4
Hello, 2 days ago i Got this driver https://downloadcenter.intel.com/download/24592/Intel-HD-Graphics-Driver-for-Windows-7-8-8-1-32-bit Intel® Download Center And I still have the same issue with D3D Error - DXGI_ERROR_DEVICE_REMOVED
Im looking for a downgrade that works but it was unsuccessfull, today I got this https://downloadcenter.intel.com/download/24346/Intel-HD-Graphics-Driver-for-Windows-7-8-8-1-32-bit Intel® Download Center and I will test it later at night Im using the lastest update of the game (but it failed too with previous versions).
The game is about a war in two islands, one is small and the other one is huge, I noticed that the problems are more frequent int the bigger islan and even more when the game needs to render a big amount of data in a short time, a cut scene ar a new mission in the air or in a plane when the video card need to render quick big amounts of information
Thank you in advance
PD:
This is my dx diag
System Information
ROBERT_U_Intel
All,,
This issue is still under investigation by our development team. I will post an update to this thread when a resolution is available.
Robert
JPala4
Thanks, but mean while Intel take its time (2 years and counting) to solve the problem, can you just provide a link for the old driver that Beelzebassie 29/11/2013 16:26
reported as fuctional?
ROBERT_U_Intel
@ jjpl2001, a Google search found the 2932 driver at various sites including the Sony support site. http://www.sony.com.au/support/download/566369?site=hp_en_TH_i Graphics Driver (Intel) Update version 9.17.10.2932 : Download : Sony Thailand
Robert
JPala4
Thank you very much Robert_Uand kevin_intel for the support.
The driver that you provided didn´t work on my laptop (unknown reason maybe 32-64 bits thing) but with the complete version number (9.17.10.2932) I was able to find working links:
32-Bits Win7/8 http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=6C95R Intel HD, HD 2000/2500/3000/4000 Windows7/8 32-bit Driver Driver Details | Dell US
64-Bits Win7/8 http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=GVR6H Intel HD, HD 2000/2500/3000/4000 Windows7/8 64-bit Driver Driver Details | Dell US
I had to un compress the installer file (3011_Video_Driver_6C95R_WN_9.17.10.2932_A12.EXE) to a folder using 7zip software and had to install the driver manually because the installer told me that "your computer does not meet the minimum requirements"
http://www.tp-link.com/no/article/?id=228 How to Manually Install Adapters on Windows 7 - Welcome to TP-LINK (like this but with video adapter)
Today I made a fast test with a specific map that was giving me problems and every thing went fine (Prologue -> Damage control mission).
I will perform a better test on weekend to see if every thing work fine as Beelzebassie reported in the list of drivers he made.
cdel1
Hi community
I still have the same issue with the brand new Intel iris 6100.
Configuration :
Intel core i5-5287U
Windows 8.1 64bits
8GB ram
Intel Iris 6100
Same error occurs randomly. I installed the latest intel's driver and running with direct x11. Any suggestion ?
Thank you
ROBERT_U_Intel
cdel1
Hi Robert. Any information on a release date ? This bug exist for almost 3 years now.
Is there a way to install the working driver on a Windows 8.1 with my Intel iris 6100 ? When I try, it says that it is not compatible.
Can I install it with my hardware on a Windows 8.0 ?
Maybe it's possible to create a version of the latest driver for the 6100 including the fix ?
Christophe
ROBERT_U_Intel
@ Christophe, We do not have a release date at this time. The engineering work on a resolution is currently still in progress. I will post a notification to this thread as soon as a resolution is available.
Robert
cdel1
Ok. During the resolution, is there a way to install the old working driver on the new 6100 ? (Compatibility issue)
This issue is "under investigation" for almost 3 years now. Every single post is closed by the mention "We will let you know when the issue is fixed".
I'm a bit scared of never beeing able to play my favorites games at all. Please can we find a solution ?
cdel1
I'm sure you have a lot of experimented engineers working on this, but may I help you ?
I'm a software engineer as well, so if you can provide a debug version of your latest driver, I can give you logs, stack traces and call stacks of the crash.
It has something related to a specific environnent, and I would be happy to help you out.
Christophe
cdel1
Kevin_M_Intel
KFlem2
Do we have news yet. I haven't tried driver 2932 yet. But I would like to see a stable solution from the Intel team. Do we have anything yet?
Kevin_M_Intel
All, resolving this issue is still a work in progress. We will post updates to this thread.
Kevin M
JPala4
As Beelzebassie reported, the drivers http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=6C95R Intel HD, HD 2000/2500/3000/4000 Windows7/8 32-bit Driver Driver Details | Dell US and http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=GVR6H Intel HD, HD 2000/2500/3000/4000 Windows7/8 64-bit Driver Driver Details | Dell US are givving me no problems related to DXGI_ERROR_DEVICE_REMOVED
The game itself have some problems, some video glitches and bugs but I think those needs to be reported to the game support center not to intell, I've benn playing for almos a week without DXGI_ERROR_DEVICE_REMOVED so I can play atleast 1 hour without problems (before downgrade I was only able to play 10 minutes)
  • Hope this works. Thank you:
Hello, First you need to install 7zip software from here http://www.7-zip.org/ http://www.7-zip.org/
Next you need to download
http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=6C95R Intel HD, HD 2000/2500/3000/4000 Windows7/8 32-bi...
http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=GVR6H Intel HD, HD 2000/2500/3000/4000 Windows7/8 64-bi...
(Whatever your system is 32 or 64)
After download, right click the downloaded driver an choose 7zi-Uncompress to (Whatever folder you want)
Next follow this tutorial: http://www.tp-link.com/no/article/?id=228 How to Manually Install Adapters on Windows 7 - W... But in step 9 you will provide the folder where you uncompressed the intel driver and in step 10 you will choose "Intel HD4000"
Follow all the steps to the end and that shoul be good.
I still have some crashing problems, but none related to driver, I can play for at least 1 hour, before I was only able to play only 10- 20 minutes
Bryce__Intel
Scatches baboul
Please read Zack's previous post and respond if you can to help in the resolution process. Much appreciated.
Bryce__Intel
Hi All,
There's a new sticky with the information required to properly investigate bugs. Could someone experiencing this issue get it in a failing state and provide the details from the sticky? I have two techs I'm aligning to get the proper attention on this, they're trying to replicate this and have not been able to so far. Hoping your information could help us so we can get this moving. Appreciate it!
Additionally one of the techs asked for game settings. See his post above post# 36
RShma
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue AND 'does it fail every single time, or only sometimes?' If you can offer a % rate please do.
DXGI_ERROR_DEVICE _REMOVED error appears after playing for a length of time on Arma 3 and game closes, happens everytime
Hardware (HW)
Brand and Model of the system.
Toshiba Satelite L850
Hybrid or switchable graphics system? ie Does it have AMD or NV graphics too?
No
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
EFP, Samsung UA22D5000NM TV
How much memory [RAM] in the system (see note2 below).
<td style="padding-right: 4px; padding-left: 4px; border-right-width: 1pt; border-bottom-width: 1pt; borde...
Bryce__Intel
Thanks MrRexeh!
We've set up our system and we're unable to see the failure. We're instead seeing the game hang and we can't get to the point of any error. Seeing if any of you've seen this and/or if you all have any ideas how to get around this. Much appreciated.
Dev notes
I did not get a chance to run the game (Gunships - Showcase) for hours, as it hangs before the soldier in the truck is even seen.
I checked with following System configuration again:
Platform : HSW
OS : Win8.1 64Bit
Driver : 10.18.10.4252
RAM : 6 GB
Display : Dell S2440L(Analog)
Resolution : 1920 x 1080
Game version : 1.48.131645
With this setup also there is same behavior, game hangs at "Gunships - Showcase".
Also played "Multiplayer – Altis" for more than an hour, this runs smoothly.
Bryce__Intel
All,
Could you uninstall the Intel graphics driver, retest this and provide your results?
We're now seeing the failure on a GT3 configuration in windowed mode without the Intel driver installed. This indicates this is not an Intel Graphics issue but perhaps an app issue. I'd like to confirm you're seeing the same thing.
