20770 ディスカッション
-BETA- 15.40.18.4380: Intel® Graphics Driver for Windows® 7,8.1,10
Bryce__Intel
従業員
21,489件の閲覧回数
IMPORTANT NOTE:Operating system support varies by platform. Due to this and a limitation of the database, Download Center search capabilities cannot report OS support accurately, so please see the support information below or reference the associated https://downloadmirror.intel.com/25749/eng/ReadMe.txt ReadMe or https://downloadmirror.intel.com/25749/eng/ReleaseNotes_GFX_15%2040%204380_Beta.pdf ReleaseNotes for more details.
BETA Notice
This beta version driver is provided to confirm pending driver code changes that address numerous reported game play issues. A list of issues addressed is contained in the ReleaseNotes. A production version driver will follow in a few weeks, if the beta tests well.
This driver is being provided as a beta test driver, and while it has had limited validation testing by Intel, it is essentially a test driver and is not to be considered a permanent replacement for a fully validated and certified graphics driver. Any issues/comments unrelated to the issues addressed in https://downloadmirror.intel.com/25749/eng/ReleaseNotes_GFX_15%2040%204380_Beta.pdf ReleaseNotes may be deleted without notice.
  • Use at your own discretion
While Intel may or may not address issues found in this beta version driver, we do welcome feedback particular to the issues listed in the ReleaseNotes that the driver addresses.
  • Please note: this driver is not certified by Microsoft* and will generate a warning when installing.
The Windows BETA driver 15.40.18.4380 has been posted to Intel Download Center at the following direct links to the driver:
This driver is in self installing format (exe) intended for end users.
32bit - NA
64bit - NA
This driver is in zip format intended for developers and IT professionals.
32bit - https://downloadcenter.intel.com/downloads/eula/25749/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40-?httpDown=https://downloadmirror.intel.com/25749/eng/Beta_15.40.18.4380.zip Intel® Beta Graphics Driver for Windows® 7/8.1/10* [15.40]
<span style="font-weight: inherit; font-style: inherit; font-size: 12pt; font-family: calibri, ve...
74 返答(返信)
kcheu3
ビギナー
2,718件の閲覧回数
Tried Potplayer beta and found that MPC-HC performed better. 4k HEVC 10bit finally can be decoded properly with 60-7x % CPU usage as expected.
CCris2
新規コントリビューター II
2,718件の閲覧回数
There is a new version of pot player 64 bit. Using H/W decode cpu is used in 4k HEVC 10bit about 20-30%
Wow it can even decode HVEC 24bit. lol
All you have to do is just set where you see Quicksync64.dll to use it.
kcheu3
ビギナー
2,718件の閲覧回数
Hi Ronin, can you show me how to setup this beta potplayer to decode 4k 10bit HEVC file? I tried the default setting it couldn't play 4k 10bit HEVC file smoothly.
CCris2
新規コントリビューター II
2,718件の閲覧回数
I am using atm version 1.6.59347 64bit from here http://www.videohelp.com/software/PotPlayer PotPlayer 1.6.59347 / 1.6.59595 Beta - Download .
Go to preferences/Filter Control / "Built-In Codec / DXVA settings"
On the left select on H264/AVC1 , H265/HVEC , and VC-1 QuickSync64.dll as video codec
On the right select use DXVA H264 Compatibility Full inspection and DXVA2 Copy-Back - Do not use.
And thats all.
kcheu3
ビギナー
2,718件の閲覧回数
Hi Ronin, I tried the latest 347 and 595 with following the instructions given but no luck. MPC is still better choice for my case. In fact, I have tried most players and found that MPC is the best at the moment.
CCris2
新規コントリビューター II
2,718件の閲覧回数
I tested some codecs and it seems that's the problem you have. Those codecs interfere with Potplayer and it works only in S/W mode.
I used shark codec pack and when I enabled ffdshow the player was working only in S/W mode. I disabled ffdshow and player is working in H/W mode.
PJ
ビギナー
2,718件の閲覧回数
What CPU/GPU do you have?
I see no CPU usage difference between PotPlayer and MPC-HC+LAV for HEVC 4K 10-bit
CCris2
新規コントリビューター II
2,718件の閲覧回数
Bryce__Intel
従業員
2,718件の閲覧回数
Hi Grof
SKL support of Vulkan is not official either, it was added to this Beta for developers to test with. Due to HW limitations it will not be added to HSW. Supporting Vulkan API in SKL production drivers is still undetermined as of yet.
RRibe9
ビギナー
2,718件の閲覧回数
Hello there. Is there any preview to having Intel HD Graphics driver for 2nd Generaion? Having lots of trouble finding the correct driver.
atzor
ビギナー
2,718件の閲覧回数
Why I still cannot install this update for my laptop (Dell Inspiron 5559, Windows 10 x64)?
I got this error: http://www.intel.com/content/www/us/en/support/graphics-drivers/000005469.html Error Message: Computer Manufacturer Graphics Driver Detected
When Dell will add this update also in their support page?
CCris2
新規コントリビューター II
2,718件の閲覧回数
The driver is not very stable yet. As you see people still have problems with it.
If you want to install this driver, uninstall the one that is installed on your pc at the moment and install this one.
Ypu may loose some features of your laptop if they customized the input output connectors.
FScho1
ビギナー
2,729件の閲覧回数
If it's a hardware bug that was reported two times in the community boards, Intel should be interested in identifying it's cause.
CCris2
新規コントリビューター II
2,729件の閲覧回数
If it's a hardware bug is not a general bug. My cpu works in windows and also in linux... and the other person I remember it has problem because he wants to run windows 7 instead of windows 10 (which is the os that his laptop came with and is working without the problems he has on win 7)
FScho1
ビギナー
2,729件の閲覧回数
http://en.community.dell.com/owners-club/alienware/f/3746/t/19659853 Alienware 17R3, Intel GPU 530 Problems - Alienware Forum - Alienware Club - Dell Community
They sound equal.
CCris2
新規コントリビューター II
2,729件の閲覧回数
Well, the manufacturer of the laptop should provide the right drivers for it, if he doesn't I would return it. It's his fault if he made a laptop with 2 video cards that don't work together.
ALam2
ビギナー
2,729件の閲覧回数
iI have similar problems with my acer g9 791 the two cards doesn't seems to work well together crash al the time , wondering is there an alternative driver that we can installed rather than Intel hd 530
CCris2
新規コントリビューター II
2,718件の閲覧回数
Finally I have an error that points to the Intel driver, more precise to the Intel dxva driver... which is on 32 bit on 64 bit browser .... hmm strange
Problem Event Name: APPCRASH
Application Name: IEXPLORE.EXE
Application Version: 11.0.9600.18124
Application Timestamp: 5641278d
Fault Module Name: igd11dxva32.dll
Fault Module Version: 20.19.15.4424
Fault Module Timestamp: 56fdc8d8
Exception Code: c0000005
Exception Offset: 0003144f
OS Version: 6.3.9600.2.0.0.256.48
Locale ID: 1033
Additional Information 1: 5861
Additional Information 2: 5861822e1919d7c014bbb064c64908b2
Additional Information 3: 1318
Additional Information 4: 13181ae637ac2592fac0ca2dd662cdcc
And as usual this error happens mostly in facebook, where the decoding is mostly used.
CCris2
新規コントリビューター II
2,718件の閲覧回数
I discovered that it it may be a problem with 32 bit dlls in video driver. After I enabled 64-bit processes for Protected mode in Internet Explorer 11 Advanced options. I was able to scroll down on facebook till the last post (filled memory till 6.5GB), without any error.
So please check the 32 bit dlls for possible errors/problems.
Thank You!
FScho1
ビギナー
2,718件の閲覧回数
When can I expect the next driver release? I'm experiencing graphic driver recoveries while using OpenGL hardware acceleration in general. Sometimes they mess up the whole window rendering in Windows 10, resulting in rectangles with crossed lines.
CCris2
新規コントリビューター II
2,718件の閲覧回数
What driver is installed on your system ?
返信
