22667 討論
BUG: dwm.exe uses memory leakage with Intel HD Graphics 630
Cody
新貢獻者 I
1,297,855 檢視
dwm.exe (Desktop-Window Manager) uses high memory with Intel Intel HD Graphics 630. This problem has been reported before:
https://answers.microsoft.com/en-us/windows/forum/all/desktop-windows-manager-dwm-memory-leakage-in/c2968fb0-ee26-4483-9f08-dfa19149cd24
https://www.reddit.com/r/windows/comments/iqttw5/windows_10_dwmexe_high_ram_usage/g4umzyn/?utm_source=share&utm_medium=web2x&context=3
Here's a screenshot of my dwm ram usage after 2 hours (1.6 GB):
Please, this bug is already known for 3-4 months, and I do not want to reinstall a 2019 driver...
1 解決方案
Gabriela_Intel
1,101,710 檢視
It seems that everyone has posted positive results so far about beta driver 101.1121 resolving this dwm leak issue. I'm going ahead and marking this thread as resolved! Please note that we'll specifically call out this fix in the release notes of our next production driver release to the Download Center which will be found here once available.
Special thanks to @HKlum@TurboTacho@Ansuel, and the MANY others that dedicated their time testing and providing various dump files. I really appreciate you all sticking by our side after all this time to make sure this long-standing problem gets resolved. You folks are what make this Community forum so great. We couldn't have done it without you! 😊
For those of you that continue to exhibit issues: Please create new individual threads so we can assess if it is a separate issue or not for your particular case.
Thanks again everyone!!
在原始文章中檢視解決方案
614 回應
Przemyslaw
新手
60,252 檢視
I am also experiencing this bug. My machine is Acer Helios 300 (i7-9750H) with Intel UHD 630 graphics and Geforce GTX 1660 secondary card and 32GB of RAM. However, the Geforce stays unused. The system version is 20H2 build 19042.630, definitely NOT a preview one. The bug started to occur quite recently, I cannot distinguish if it was related to updating Windows to 20H2 or related to updating the Intel drivers - their version is 27.20.100.8681. I do not install anything manually, all comes from Windows Update. The Windows installation is vanilla, not the one installed by the OEM. I did not update the BIOS, neither did I anything unusual. Some extra observations that may add something:
- My working set size of dwm.exe is between 2,0 - 2,5 GB
- I do not use hibernation
- The machine is rarely restarted, I use sleep very often
- This week it was restarted on Saturday and the memory leak occured on Tuesday. Before Tuesday it was ca 150MB.
- It might have something to do with sleep. I am monitoring the working set size with Performance Monitor and found out, that the memory increased some time after the wake up, but didn't catch the exact moment. On the other hand, by then it had already completed a few other sleep-wakeup cycles (Sunday, Monday) before, and it was fine.
- I use the screen saver. That's unusual, but not sure if there is a relationship. It is standard Windows Text3D screensaver.
- Some time before I observed the 2GB usage, I launched modern UWP remote desktop client application. Not sure if there is any relationship. Maybe something after launching UWP apps.
- I use classic mstsc RDP client very often, probably this is not relevant.
TurboTacho
新貢獻者 II
60,039 檢視
I've noticed that majority of the posters in this thread have Nvidia GPUs. I was wondering could it be something to do with the GPU switching or some kind of parallel rendering that's leading to the massive leak?
Unless if the Intel driver is not integrating well with the Nvidia Optimus setting, just some wild intuition running in my mind... Based on what I've read online, it seems that the Intel driver is in full charge of the switching depending on GPU demand per application.
Cody
新貢獻者 I
59,868 檢視
@TurboTacho
This was also my suspicion earlier, but disabling nvidia drivers didn't make it better. However there might be other nvidia software running too that cannot be disabled, interfering with Intel GPU and thus cause this bug.
Maybe intel lab has a computer with a double gpu (intel+nvidia) to test?
TurboTacho
新貢獻者 II
59,364 檢視
@Cody Yes, seems like the non-dedicated GPU users are also having this issue as well.
Anyway, I've tried several ways to replicate this DWM issue in a much easier manner. Turns out it's actually possible in certain ways.
Earlier on I tried creating a few video projects via the Microsoft Photos app. The projects consist of a simple picture and video slideshow with music, about 8 to 12 minutes long each. The export process was sufficient to indicate and trigger the memory leak in DWM without delay. (I additionally confirm that Nvidia GPU wasn't activated during the exporting process at any time.)
End result: 17GB memory consumption after 4 simple video projects completed.
I've also noticed that in most occasions, this memory leak occurs when I use the 'Shut down' button in Windows, and then booting up the laptop. If I were to restart the system, the memory leak issue is briefly resolved for about 4-6 hours upon logging in.
I strongly believe the hybrid shutdown or Fast Startup might be one of the cause of this issue. Definitely it is frustrating when the leak isn't fully addressed, but could only be temporarily resolved through workarounds which may not be feasible in the long run.
smithy
新手
58,559 檢視
So I ran VMMap by sysinternals on DWM.exe.
Started at 45mb, then 70mb, then 135mb, slowly creeping up.
I then did a hibernate/sleep, then powered up again, massive increase to 285mb. It seems that in the memory, the image data stays around 43mb, but the private data and heap are the culprits.
Not so much private data but the heap.
If you look at the screenshot below, it seems it keeps making strings in the heap of size 16,188kb.
The amount of instances of 16,188kb keeps increasing leading to DWM.exe taking up more RAM.
This is beyond my RAM/memory knowledge, but need someone to work out what is causing this increasing in commit, I assume its not flushing the old unused ram out, so keeps ever increasing...
Anyone knows how to do this? Intel surely knows how?
smithy
新手
57,983 檢視
smithy
新手
57,945 檢視
Now at 627mb ram use and counting...
Got to be security implications as well with this memory leak...
If i look at the strings within each address I see loads and loads of them with just the string "cqTY"
smithy
新手
57,898 檢視
@AndrewG_Intel
Can you please see previous posts?
RonaldM_Intel
主席
57,890 檢視
Hi everyone,
Thank you for all your input. I am still trying to replicate the issue and used the same hardware as before and this time setting up a VM with VirtualBox and running Ubuntu while making sure hardware acceleration is enabled in the VM... bad news is that I'm still unable to see the issue.
Can you upload your SSU files? this information should help us identify what could be triggering the issue on some systems but not on all.
TurboTacho
新貢獻者 II
57,889 檢視
You could try creating a few photo slideshow with music with the Microsoft Photos application, that caused my DWM to "inflate" into a massive memory leak.
I've also re-attached my SSU files for your convenience.
Cheers
validate
新手
58,116 檢視
I also have that leakage bug with just UHD 620, without NVIDIA card.
Rootless
初學者
58,054 檢視
I'm using an HP Spectre x360 with an i7-8705G processor and am experiencing this bug too with 27.20.100.8783.  No NVIDIA here.
Przemyslaw
新手
58,003 檢視
I got it! After couple of days of running Performance Monitor (standard Windows tool) focused on dwm.exe process, now I know what causes the rise of the memory consumption.
In my case, it is running Oracle Virtual Box 6.1.16 (the newest, but internal VBox additions are 6.1.12) with linux virtual machine (kernel 4.15, LinuxLite distribution), VMSVGA graphics adapter and 3D acceleration enabled.
After the reboot, the usage was 150MB and it was stable for 2 days. Today I ran VirtualBox and it immediately increased to ca 400MB. I ran it again and now it is 600MB. It is NOT released upon closing VirtualBox. This behavior seems to be reproducible. Ran for the 3rd time, and now it is 730MB.
I know, it looks like Oracle is to blame in my case, because it is not very probable that other affected users also run VirtualBox. However, I suppose it may have something to do with applications that use 3D hardware acceleration.
Rootless
初學者
57,981 檢視
I don't have Virtual Box installed, and it still happens to me.
smithy
新手
57,974 檢視
Getting the same bug, HD630 plus nvidia 1050ti on laptop.
DWM.exe gets to 3-4gb
Could someone use this to find the leak and tell intel:
https://docs.microsoft.com/en-us/windows-hardware/drivers/debugger/using-umdh-to-find-a-user-mode-memory-leak
Really annoying as it eats into ram use.
need a fix soon please.
sandtechnology
57,278 檢視
@AndrewG_Intel Hey, I have generate a compare log according to  @smithy 's link, also a SSU log, hoping it will help in debugging.
sandtechnology
57,265 檢視
@RonaldM_Intel Also a right tagging and another comparing results.
smithy
新手
57,256 檢視
it would be great to get a hotfix/driver update for this asap.
Przemyslaw
新手
57,898 檢視
Here are my SSU logs.
Further observations about the case of VirtualBox: the memory usage did not stop increasing when I closed the virtual machine. It keept increasing continuously since then. I restarted the system when it reached 3GB, now stays at 150MB for more than a day.
Vivisector
初學者
57,773 檢視
I've had this issue as well. In the process of downgrading my driver since nothing else has worked. I also want to note that the new XBox App and Steam seem to slam DMW and cause its memory usage to increase a lot. I don't think they're at all related to the bug but using the Xbox gamepass app and then closing it out to see if DMW clears may be a more reliable test to see if there's a leak.
回覆
