22785 Discussions
Beta Intel® Iris™ and HD Graphics Beta Driver for Windows* 7/8/8.1 for TITANFALL* and Thief*
ROBERT_U_Intel
UPDATE: The beta program for this driver is now closed. Please find the released drivers at the following links:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23713 Windows 32-bit
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23714 Windows 64-bit
Discussion on this driver should be directed on this thread: /thread/49681 https://communities.intel.com/thread/49681
Thanks all who participated in the beta driver program. Your feedback was very much appreciated.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23644 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23644
RVand51
I too am having this same issue. Really hope this gets updated soon.
ROBERT_U_Intel
@CooperArt,, If your specs you posted are correct your graphics are not supported by the beta driver. The Intel(R) Core(TM) i7 CPU L 620 is a Intel® Core™ Processors with Intel® HD Graphics. This is a 1st generation HD Graphics processor.
The beta driver only supports the 3rd and 4th generation HD graphics. The installer is correct that the system does not meet system requirements.
Robert
PAUL_P_Intel
We have released a BETA ONLY driver for Titanfall and Thief. These drivers come with "As Is Support". Please note these are NOT PRODUCTION drivers for any current products. Please feel free to post any results from trying the driver. We would appreciate the feedback on anything related to the performance of the driver both positive and negative. If you have any system instability please uninstall the BETA ONLY driver and reinstall the production driver for your product.
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23644&lang=eng&wapkw=titanfall Download Center
Paul
Intel Support
TUppe
Just as an FYI:
I have a Lenovo ThinkPad Twist with a 3rd Gen i7 and Intel HD 4000. When I installed the beta driver, I had a similar experience as others. My built-in display would not be detected (it wasn't listed in Device Manager or the Screen Resolution menu), but I could connect to an external display. I tried to play TitanFall on the external display, but it would force quit every time. With the current stable driver, TitanFall loads just fine, but I get that crazy graphics glitch.
Don't know if that's helpful at all.
EDIT: With the beta driver installed and an external monitor connected, I can play TitanFall! It force quits when I try to play the game from the desktop shortcut, but works fine when I start it through Origin. Doubt that's an Intel issue, but thought it might be helpful to someone else reading the forum.
Message was edited by: Timothy Upper
UUdoe
The driver update does not work and titanfall is still bugged. I've tried plugging my hdmi labtop to the TV to see if the TV display graphics differ, but they are the same. I've set the 3d general settings to quality rather than performance. I have no idea what else to do.
ROBERT_U_Intel
@ bigticketub,, what are the specific issues you are seeing with the game? Can you also provide specifics about your system configuration?
UUdoe
http://www.youtube.com/watch?v=KYPlOoyNhh4 http://www.youtube.com/watch?v=KYPlOoyNhh4
I'm seeing things along the line of this. Using intel HD 4000 card, Windows 8, 64 bit, Intel(R) Core(TM) i7 -3520M CPU @290 GHz processor.
TUppe
@bigtickethub I have the same specs as you and had the same issue. I had to manually load the beta driver.
1. Login with administrator privileges
2. Open Control Panel
3. Open Device Manager
4. Click on "Display adapters"
5. Double click "Intel HD Graphics"
6. Click on the "Driver" tab
7. Click on "Update Driver" button
8. Click on "Browse my computer for driver software"
9. Click on "Let me pick from a list of device drivers on my computer"
10. Click on "Have Disk" button
11. Click "Browse"
12. Navigate to the folder that you unzipped the Beta Intel HD Graphics driver to
13.Navigate to the Graphics sub-folder
14. Double click the igdlh64.inf or igdlh.inf file <-- depends on if you have 32 or 64 bit OS
15.Click "OK"
16. Click "Next"
Driver should now be installing.
17. If successful, click "Close"
Reboot.
Doing this, however, gave me the black screen error I mentioned earlier.
UUdoe
How would I log in with admin priveleges? I just attempted to reinstall it for the 3rd time, to no avail it still doesn't work
UUdoe
@tuppers, My accountss already admin, but I've done this, and it doesn't seem to do anything for my game and labtop screen isn't blacked out.
DKim47
I've seen someone who's in a similar situation as you. He got it working by uninstalling his old driver and installing this beta driver instead of just "upgrading" the driver
AAlle6
I attempted to install the graphics driver for my HP Envy 17- j010us notebook ( Windows 8.1 64-bit, Core i5 3230 M, Intel HD 4000 graphics), however the driver has led to my laptop being unable to detect its screen so it's black (even though the laptop itself is working fine). It looks like my only solution is getting an HDMI cable and hooking it up to my TV because restarting the laptop with ctrl+ f8 has proven impossible. I understand that my best bet is to rollback to my previous driver, however I wanted to know if the driver will eventually be compatible and usable because I'd love to play Titanfall, but so far it seems like the driver isn't making that possible unless I play through a different monitor, but I'd prefer to play on my laptop solely.
ROBERT_U_Intel
Mobile / Laptop users, Please post what operating system you are seeing the blank screen on when you install the beta driver. Also, if you haven't already, please post the make and model of your laptop.
Robert
DKeha
I'm running Windows 8 (not 8.1) 64 bit, on a Lenovo G580. I have an Intel i5-3210M clocked at 2.50 GHz and an intel HD 4000.
TUppe
I'm running Windows 8.1 64- bit on a Lenovo Thinkpad Twist.
JChan107
Running Windows 8 64 bit on Macbook Pro 2012 with Intel HD 4000 512 MB Graphics, 8 GB 1600 MHz DDR3 Memory, 2.9 GHz Intel Core i7 Processor. Keep having issues with the black screen after installing beta drivers.
ccarp
With the previous drivers I was experiencing the banding bug and absent gun issue.
After manually loading the driver, I encountered a black screen 1) after finishing the setup for the drivers 2) after a hard reboot of the system. I had to restore from a save state from this morning to recover.
Toshiba Satellite C855
Windows 8.1 64-bit
Intel Core i3-3120M 2.50GHz
6.00 GB Ram
Edit: I tried installing it first without removing the old driver and then second by uninstalling the old drivers. Both times resulted in black screen
DKim47
Yep i forgot to mention that i did it with old driver AND without old driver and both resulted in black screen
zmura
im also experiencing this messed up graphics. my specs below:
http://www.youtube.com/watch?v=KYPlOoyNhh4 titanfall beta intel hd 4000 (graphics bugs) - YouTube
CPU: intel core i5-3320M
RAM: 4GB
OS: 64bit Windows 7
VGA: Intel HD Graphics 4000 (version 8.15.10.2712)
mmend12
i put in the beta drive, and my laptops screen turned black, i did this every time i change the drive, but i used my tv hdmi for the screen, i tried titanfall (game) out on the tv with the beta drive and it works great! i see my gun and no weird body warps. so if there is a fix for the black screen please post.
dell laptop
window 8.1
inter i3 cpu @ 1.9ghz
64 bit os
4 gb ram
cmule
I have a lenovo G510 running on windows 8.1 64 bit. 4th Generation Intel Core i5-4200M Processor (3.10GHz 1600MHz 3MB).Intel® HD Graphics 4600. memory 8.0GB PC3-12800 DDR3 SDRAM 1600 MHz. hard drive1TB 5400 RPM. please help.
