22657 Discusiones
Black screen after installing 8.15.10.2086
Empleados
62.843 Vistas
Add me to the list of people who get a black screen....
HP G60t-200CTO
Windows 7 64 bit.
I uninstalled the previous intel driver (8.15.10.1986) and installed 8.15.10.2086.. and got a black screan... grrr... Other older intel drivers have worked just fine so I don't agree that it's a special vendor bios issue.
-Devoh
0 kudos
247 Respuestas
Empleados
2.632 Vistas
Please indicate the date when the problem will be solved! your silence is disquieting.
Empleados
2.632 Vistas
Robert_U from Intel last posted on 4/26/10 saying it was being worked on.. I'm doubt they can give a date it will be fixed. I'm glad this is being taken seriously now. I also hope Intel has more than just Robert_U looking into this. Please keep sending in more info.
-Devoh
Empleados
2.632 Vistas
I believe that I am having the same problem. I have built a PC with the following spec:
Motherboard - Intel DH57JG Mini ITX
Processor - Intel i3-530
RAM - 2x1GB Corsair XMS3 DDR3 1333MHz Dual-Channel
HDD - Western Digital Caviar Blue 500Gb
Optical Drive - Lite-On IHOS104-37 Blu-Ray Reader
OS - Windows 7 Home Premium 64-bit
Display - Samsung 32" 1080p LCD TV via HDMI 1.3
I am still running on the basic VGA drivers that come installed on the motherboard as I haven't found an Intel HD Graphics driver that works yet.
Because of this I don't know how to produce the system report (when i right click on the desktop there is no "Graphics Properties" option.
Any help with this would be much appreciated.
ROBERT_U_Intel
Empleados
2.632 Vistas
A modified version of the 15.17.1.2104 driver has been posted that may, and I stress may resolve this issue on Intel® HD Graphics, Mobile Intel® 4 Series Express Chipset Family and Intel® G4x Express Chipsets. Please feel free to try the driver from the links below and report back on your results.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18400 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18400
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18402 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18402
Empleados
2.632 Vistas
2104 is the one that Microsoft pushed via Automatic Updates as well and it's a no go
Again, I don't have a black screen - I have a frozen Microsoft Windows Logo, when my laptop keeps booting into windows. The laptop itself is not hung, but the video is.
ROBERT_U_Intel
Empleados
2.632 Vistas
Did you install the driver from the links in my previous post?
Empleados
2.632 Vistas
Driver install without BSOD (already good ), but after a reboot got BSOD (error in igdkmd32.sys).
PS. I tried to install the driver on the link - http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18400 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18400
Empleados
2.624 Vistas
Sony laptops are 1600x900 Just fyi, can't wait to get it updated.
Thank you.
Empleados
2.624 Vistas
No luck with Acer 5740-5780 Robert. However, I understand this driver only fixes 1400/1600 resolutions, not 1366 768.
Here is my info again, BIOS is 1.22, the latest.
Intel® Graphics Media Accelerator HD (Core i3)
Report Date: 5/12/2010
Report Time[hr:mm:ss]: 16:18:29
Driver Version: 8.15.10.2021
Operating System: Windows 7 (6.1.7600)
Default Language: English (United States)
DirectX* Version: 10.0
Physical Memory: 3764 MB
Minimum Graphics Memory: 128 MB
Maximum Graphics Memory: 1754 MB
Graphics Memory in Use: 16 MB
Processor: Intel64 Family 6 Model 37 Stepping 2
Processor Speed: 2127 MHz
Vendor ID: 8086
Device ID: 0046
Device Revision: 12
* Accelerator Information *
Accelerator in Use: Intel(R) Graphics Media Accelerator HD
Video BIOS: 1994.0
Current Graphics Mode: 1366 by 768
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 13.39 inches
Vertical: 07.48 inches
Monitor Supported Modes:
1366 by 768 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 06 AF EC 20 00 00 00 00
01 12 01 03 80 22 13 78 0A 57 55 9C 5A 54 9D 26
1A 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 26 1B 56 47 50 00 26 30 30 20
34 00 58 C1 10 00 00 18 00 00 00 0F 00 00 00 00
00 00 00 00 00 00 00 00 00 20 00 00 00 FE 00 41
55 4F 0A 20 20 20 20 20 20 20 20 20 00 00 00 FE
00 42 31 35 36 58 57 30 32 20 56 30 20 0A 00 2E
* Other names and brands are the property of their respective owners. *
Empleados
2.624 Vistas
Intel® Graphics Media Accelerator Driver for Mobile Report
Report Date: 5/13/2010
Report Time[hr:mm:ss]: 0:23:8
Driver Version: 8.15.10.2057
Default Language: Persian (Iran)
Physical Memory: 2940 MB
Maximum Graphics Memory: 1342 MB
Graphics Memory in Use: 38 MB
Processor: x86 Family 6 Model 23 Stepping 6
Processor Speed: 2259 MHz
Vendor ID: 8086
Device ID: 2A42
Device Revision: 07
Accelerator in Use: Mobile Intel(R) 4 Series Express Chipset Family
Video BIOS: 1629.0
Current Graphics Mode: 1600 by 900
ROBERT_U_Intel
Empleados
2.624 Vistas
Just a quick note,, we are continuing to investigate this issue however, it is difficult to root cause as we have not been able to replicate the issue on the systems we have available for debug. We are continuing to try and replicate this issues as we locate additional systems.
Empleados
2.624 Vistas
Thank you for trying to solve the issue, but the part about unable to duplicate it puzzles me... You work for Intel, so either buy an Acer 5740-6491 (about $600) or ask Acer to supply you with one for a month. I'm sure they would be more than glad to oblige, given that this bug affects most/all of their current laptops and it seems a few others.
I tried 2086/2104/2119/2125 drivers, all with the same result, being that when you install it first, you get a black screen with blinking cursor and when you reboot you get the windows logo even after it actually entered Desktop screen. If during either of those moments you RDC to the computer, Windows7 thinks that everything is working just fine (no errors anywhere). I tried connecting HDMI to my 1920x1080 TV and switching to external monitor, but nothing came up.
Empleados
2.624 Vistas
INTEL -
I AGREE WITH ABOVE. I DON'T QUITE UNDERSTAND WHY YOU CAN'T REPLICATE THIS ISSUE. IT INVOLVES MANY DIFFERENT BRANDS OF COMPUTERS. YOU SUPPLY THE INTEL CHIP TO A LOT OF MANUFACTURES, THEREFORE, IT APPEARS YOU SHOULD BE ABLE TO COME UP WITH A SOLUTION. MICROSOFT IS ALSO AWARE OF THIS ISSUE BECAUSE I HAVE TALKED TO THEM SINCE THEY PROVIDED THIS UPATE AS AN OPTIONAL UPDATE. THEY ARE ALSO WAITING FOR YOU BECAUSE THEY ARE AWARE OF THE PROBLEM AND I'M SURE ARE SORRY THEY RELEASED YOUR UPDATE AS AN OPTIONAL UPDATE BECAUSE THEY ARE GETTING THE SAME QUESTIONS. HOWEVER, THERE IS NOTHING THEY CAN DO ABOUT IT SINCE IT IS YOUR UPDATE AND NOT A MICROSOFT UPDATE.
THANKS VERY MUCH!
Empleados
2.624 Vistas
Same issue. Computer was working fine until I installed the .2104 update.
Here's the config:
Sony VGN SR290
Intel Core 2 Duo P8400
3 GB RAM
Windows 7 Professional (32 bit)
Intel 4 Series Express
If I load up in Windows 7 Safe Mode and disable the graphics accelerators (there are two? And I have only onboard graphics!) and then restart to normal boot up, I can load a regular session of windows with no graphics acceleration (also my CPU gets ridiculously hot then).
Please find a fix asap. This is a major problem.
Empleados
2.624 Vistas
Also,
My resolution is 1280x800 and I can't even use System Restore. I have 4 restore points before this update was installed and they're all suddenly corrupt. Basically I have to run my computer with the display adapter disabled now, and that's the only way I can even boot up. This is a major, major issue and I hope you'll are working on an update.
Empleados
2.624 Vistas
I may have found a fix. This is what I did to get it working again:
1) Boot up in safe mode and disable all display adapters.
2) Restart computer to normal windows startup.
3) Download the original video drivers for your model from your manufacturers website (in my case it was the Sony Vaio video drivers from October of last year)
4) Install the original video drivers
5) Restart into safe mode again, disable one of the display adapters
6) Restart into normal mode again, and download version 2021 of the Intel driver (http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18944&ProdId=2991&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18944&ProdId=2991&lang=eng)
7) Install the drivers and restart normally
😎 Enjoy beautiful Aero and not burning up your cpu!
Empleados
2.624 Vistas
Your method did not work. The system was restored after the restart, but in Device Manager version of the video driver is updated to 2021. The CPU is also hot!
Empleados
2.624 Vistas
Robert_U,
Can Intel make a extended info gathering tool that we can run to help gather more info? I'm sure many of us out here would be more than happy to run some stuff to gather any info that might help. We REALLY would like a fix.
-Devoh
Empleados
2.624 Vistas
I refused the integrated graphics on my laptop, because the CPU temperature rises to 10 degrees! Maybe someone knows the reason? If you use ATI HD 4300 CPU temperature, on average - 48 degrees Celsius, and the use of Intel, the temperature rises to 60 degrees! This may be the cause of the driver?
Empleados
2.624 Vistas
Same problem here with a brand new acer aspire 5740-6491 (windows 7 x64 - core i5 430m). Updating to the newest drivers result in a black screen with a blinking cursor at the moment of installing the drivers, and computer will freeze after loading windows.
I was able to roll back to the original drivers that came with the computer (an older version) in safe mode.
Empleados
2.627 Vistas
softoys - the reason that your processor temperature rises when using onboard graphics is because the processor is doing a lot more work as opposed to when the additional graphics card is in use.
Has anyone looked at their Windows Event Log when after they have had a black screen after installing the drivers? After I installed the drivers and subsequently removed them after my PC crashed I investigated the Event Log and googled for the latest critical event IDs. This lead me to a few forums in which I eventually manage dto find a fix that worked with my system.
The fix that worked for me was to disable all the C State options in my BIOS settings. I'm not sure why this worked, maybe a conflict with the power management software and the graphics driver.
Responder
