I just opened my brand new https://www.acer.com/ac/en/US/content/model/DT.B7YAA.002 Acer ATC-780-UR12, running Windows 10 (64-bit) and integrated Intel HD 630 graphics card.
The graphics card has an HDMI and a VGA port. My HDMI monitor has no problems. My VGA monitor, on the other hand...
Text is blurry. Images have a fade/shadow on the right - like a cartoonist's representation of motion. Open windows, regardless of size or position, have a red-lined left border and a green-lined right border.
I have tried rebooting with only the VGA monitor plugged in. I have tried two different VGA monitors. I have set a custom aspect ratio of 100%.
I tried installing the latest https://downloadcenter.intel.com/download/27267/Graphics-Intel-Graphics-Driver-for-Windows-15-40-?product=80939 driver, but the installation failed: "This computer does not meet the minimum requirements for installing the software".
I have attached the SSU information. Also:
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
VGA display:
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)EFP = External Flat Panel (Monitor you plug in)
(did not see this info on the SSU)
HDMI: http://www.sceptre.com/overview-221.html Sceptre E205W
VGA: Optiquest Q9
How much memory [RAM] in the system (see note2 below).
8 GB
<td style="border: ...Link Copied
Regarding the driver, select from this list https://downloadcenter.intel.com/product/98909/Intel-HD-Graphics-630 Downloads for Intel® HD Graphics 630
A new error on that one:
"The driver being installed is not validated for this computer. Please obtain the appropriate driver from the computer manufacturer."
Install driver via "have disk method" as described at:
http://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface http://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface
(ignore prolog about MS surface)
EDIT: if link is broken, copy and paste
That did enable me to install the newer driver, thanks.
Unfortunately, the VGA display problem persists.
Check out:
https://ark.intel.com/products/codename/82879/Kaby-Lake Products formerly Kaby Lake
Graphics Specifications
Processor Graphics ‡ Intel® HD Graphics 630
Max Resolution (VGA)‡ N/A
https://www.intel.de/content/www/de/de/processors/core/7th-gen-core-family-mobile-u-y-processor-lines-datasheet-vol-1.html 7th Gen (U/Y) and 8th Gen (U Quad-Core) Intel® Processor Families...
DP-to-VGA converter on the processor ports is supported using external dongle only, display driver software for VGA dongles which configures the VGA port as a DP branch device.
If i understand that correctly there must be some extra hardware on your motherboard that is not made by Intel, but by Acer.
I would ask at www.acer.com/ac/en/US/content/support if that can be fixed from their side (potentiometers settings, whatever).
I am assuming there was some physical problem with the hardware. I had a new one shipped out and it works fine.
Thanks for taking the time to help with this!
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
