23279 Discussions
Can I leverage my Intel Onboard Graphics to allow me to view my desktop across 2 screens - i.e. have both screens act as a single desktop
AGavr9
The aim of this activity would be to allow me to maximise my Citrix Workspace window across the two monitors to allow dual screen use (Citrix allows for the window to be split into screens when used)
Currently, when I extend my desktop across the screens, I can only maximise an application/window in one screen, what I would like is the ability to maximise the window and it to span across two screens
I've tried just stretching the window for my virtual desktop, but it gets too messy without being able to maximise the window
I have an HP Spectre x360 running Windows 10 with an Intel UHD Graphics 620
AdrianM_Intel
Hello AGavr9,
Regarding your question, the available options that you can use are the ones provided by the operating system (Ctrl + P) like duplicate screen, extended, etc. Also, in Intel® Graphics Command Center you can change the options as well for extended, duplicate, collage, and clone.
Collage Display is a feature that enables you to share one image across multiple independent displays.
If you can maybe share screenshots or a video about the configuration you would like to make on your system so we can take a look at it
Adrian M.
AGavr9
Hi Adrian,
The native options in Windows 10 don't facilitate maximizing a window across 2 monitors, as if you select "Extend", it will still treat the two monitors as separate, only allowing you to maximize a window across one or the other, but not both
In terms of the Intel Graphics Command Center (or the Intel Graphics Control Panel as I've found it on my device - is this the one?) - I've only found the options to Extend or Duplicate the display - the collage option sounds like it might work - essentially being able to maximize a window across the two screens (which, in this example is a citrix window), but I don't see that available?
Let me know of anything else that would help
Kind Regards
n_scott_pearson
Not sure anything will help. I remember it being there years ago, but I haven't seen support for Collage mode for quite some time.
n_scott_pearson
The capabilities differ from one model of the X360 to another, so I cannot be specific, but you can hook monitors to the USB-C port(s) on this laptop and have independent displays on each (and each is capable of supporting up to 4K@60Hz). A cable like this: https://www.amazon.com/uni-Thunderbolt-Compatible-MacBook-Surface/dp/B075V5JK36 will connect a monitor to a USB-C port.
AdrianM_Intel
Hello AGavr9,
Were you able to check the previous post?
Adrian M.
AGavr9
Have done so and replied above Adrian
AdrianM_Intel
Hello AGavr9,
Thank you for your reply.
It's worth mentioning that in order to have the collage mode feature enabled, you will need a third monitor since the built-in display of the laptop does not count as a monitor to perform the collage mode.
The minimum amount of monitors to perform a collage mode is 2.
If possible try to test by connecting another monitor to your laptop, if possible straight connected since adapters/docking stations might change the behavior of the features available.
Adrian M.
AdrianM_Intel
Hello AGavr9,
Adrian M.
AGavr9
Hi Adrian,
I've got a 2nd Monitor connected, but have done so through a USB-C connector as the monitor only has DVI-D and HDMI inputs and the laptop only has USB-C outputs
Surely in this case it wouldn't be the connector that is providing the issue? - it's an HP accessory so ideally approved by HP
Kind Regards
AdrianM_Intel
Hello AGavr9,
Our recommendation is to perform straight connections without adapters/dongles however I understand the computer only has USB-C outputs.
So you might try with it and check if the option is available since the built-in display can not be used to perform the collage mode.
Adrian M.
AdrianM_Intel
Hello AGavr9,
You might check Frequently Asked Questions for Collage Display Mode.
You may ask to the software developer or check with MS* support if there is another option you can try to use the set up you are looking for.
Adrian M.
A Contingent Worker at Intel
