公告
22735 讨论
Code 43 when installing latest HD Graphics Driver on Windows 10 with the HD 5500
DRemm
初学者
5,875 次查看
On a Dell XPS I have been unable to successfully install any of the versions of the graphics drivers from the Intel site or the Dell site. After many searches, I haven't found a solution. Is this a known problem, or is a solution available?
0 项奖励
12 回复数
Amy_C_Intel
员工
3,839 次查看
Hello jb81,
Please safely uninstall the Intel driver http://www.intel.com/support/graphics/sb/CS-034574.htm Graphics Drivers — Uninstalling the Intel® Graphics Driver and Intel Display/HDMI Audio Driver and then install it https://downloadcenter.intel.com/download/25484/Intel-Graphics-Driver-for-Windows-7-8-1-10-15-40- Download Intel® Graphics Driver for Windows® 7/8.1/10* [15.40] following these instructions http://www.intel.com/support/graphics/sb/CS-033916.htm Desktop graphics drivers — How to Manually Install a Driver in Microsoft Windows 8* or Windows 8.1*.
If the issue persists try the following;
For more details https://technet.microsoft.com/en-us/library/cc725873%28v=ws.10%29.aspx?f=255&MSPPError=-2147217396 Code 43: Windows has stopped this device because it has reported problems.
Amy.
0 项奖励
DRemm
初学者
3,839 次查看
Amy,
I've uninstalled and reinstalled the driver as directed, but the following message appears at the end of the install process:
I also tried the:
instructions with no luck.
Dale
0 项奖励
DRemm
初学者
3,839 次查看
I see that I forgot to give the full name of the Dell laptop. It is the Dell XPS 13 9343.
Any other suggested fixes or workarounds?
Dale
0 项奖励
Amy_C_Intel
员工
3,839 次查看
It's unfortunate that you have this issue with our generic driver, at this point I would recommend installing the driver from your computer manufacturer.
Please refer to the following post
Amy.
0 项奖励
PIvan3
初学者
3,839 次查看
I'm having the exact same issue, except with the HD4600 Driver on Windows 10. I tried installing the latest drivers from https://downloadcenter.intel.com/product/81496/Intel-HD-Graphics-4600-for-4th-Generation-Intel-Core-Processors Downloads for Intel® HD Graphics 4600 for 4th Generation Intel® Core™ Processors . I also tried installing the driver provided by Asus (because I have an Asus H97ME motherboard). But no luck, with the official drivers the analog output always goes to random noise. The only way to get it to work is with the Microsoft Basic Display Adapter, but performance is sluggish and the second screen only works if it is properly turned on when the PC boots.
I also tried the link with the Driver update utility, but this lead to the same issues.
Any thoughts on how to fix this?
With kind regards,
Paul
0 项奖励
Amy_C_Intel
员工
3,839 次查看
Hello Paul99,
Have you tried installing the driver with the following method http://www.intel.com/support/graphics/sb/CS-033916.htm Desktop graphics drivers — How to Manually Install a Driver in Microsoft Windows 8* or Windows 8.1*?
Could you please be more specific about "the official drivers the analog output always goes to random noise"?
Thank you.
Amy.
0 项奖励
PIvan3
初学者
3,839 次查看
Hi Amy,
Thanks for your reply. I did try to install the drive with the method you mention. But during the process I always get a BSOD with the message as you can see in the attached image.
I also tried to uninstall the graphics drivers in safe mode and then reinstalled the latest beta driver (but this happens with all versions) from your download site. But then at the end of the installation process the screen starts showing random noise (so fullscreen colored random noise) on the VGA port (analog output). When I reboot the machine the Intel4600 is showing code 43 again, so that probably means that it is using the Microsoft Basic Display drivers again.
Any ideas?
Paul
0 项奖励
Amy_C_Intel
员工
3,839 次查看
At this point since you tried with our graphics drivers with no success I would recommend to install the driver from your computer manufacturer, give it a try http://www.asus.com/ ASUS USA.
Regards.
0 项奖励
Amy_C_Intel
员工
3,839 次查看
Hello all,
Please uninstall the Intel driver that you have installed, you can follow these instructions http://www.intel.com/support/graphics/sb/CS-034574.htm Graphics Drivers — Uninstalling the Intel® Graphics Driver and Intel Display/HDMI Audio Driver, then run the batch file attached and finally please go ahead and install the latest driver version following these instructions http://www.intel.com/support/graphics/sb/CS-033916.htm Desktop graphics drivers — How to Manually Install a Driver in Microsoft Windows 8* or Windows 8.1*.
0 项奖励
PIvan3
初学者
3,839 次查看
Hi Amy,
Thanks for your help. I tried the batch file, but it does not change anything. Even when I run the batch file as Administrator or manually delete and make sure all igfx* files are gone. I'm afraid this will require a reinstall in windows 10 (hopefully that fixes it). I also bought an nvidia graphics card, but that one does not want to work either.. I will report back after reinstalling windows.
Paul
0 项奖励
PIvan3
初学者
3,839 次查看
Hi Amy,
Reinstall of windows 10 fixed it all! Seems like updating win 7 to win 10 is not as smooth as it could be. Thanks for your efforts!
Paul
0 项奖励
Amy_C_Intel
员工
3,839 次查看
You're welcome, thank you for sharing this information. If you need further assistance let us know.
Amy.
0 项奖励
回复
